Strange DIC messages and Code Reader
Old Nov 5, 2013 | 07:36 AM
pm317's Avatar
pm317
Cruising
Default Strange DIC messages and Code Reader
Where is the best deal on buying a code reader? I have a 2005 C6 LS2 and I'm a first time owner. I'm trying to make sure I keep everything running smooth. So far I've had a lot of messages in my DIC.
i.e. left front tire flat, service electric charges, ? FOB Run or Go?, etc. None of these messages seem to be true and it feels and sounds and drives great. Any ideas? Thanks!
Old Nov 5, 2013 | 07:52 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
well the FOB message comes from attempting to shut the car off without a FOB in close proximity
Old Nov 5, 2013 | 07:56 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Most likely your battery is going dead.
I bought a fancy (expensive) code reader since it should be a one time investment in a tool. I think I was wrong in this case. The most inexpensive reader is probably just as good since you normally end up looking for a solution to the code on the internet anyway. My Actron is a quality instrument that has paid for itself several times over even with the high initial cost. I would have no problem recommending the least expensive Actron.
Old Nov 5, 2013 | 08:01 AM
truckplay's Avatar
truckplay
you can buy a code reader online or just about any parts store $50-$80.
flat tire warnings can be weak batteries in the old tpms sensors ( 05 car )
"service charging system" can be due to weak battery, aftermarket plugs & wires or just the proximity of the driver front spark plug wire to the alternator. check the battery 1st, if it is 3 years old it is on it's last legs.
"no fob detected" is due to weak batteries in the fob.
Welcome
__________________
Tom
To Strange DIC messages and Code Reader
