re: Rodent deterrent
Old Nov 6, 2013 | 04:59 PM
c6vette142dude's Avatar
c6vette142dude
Default re: Rodent deterrent
For those of you who do, or who have lived in rural areas, what were some effective rodent deterrents that you used... besides traps? I've heard that Ivory soap works wonders. Any other ideas?
Thanks!
Old Nov 6, 2013 | 05:05 PM
sledmaster's Avatar
sledmaster
Get some cats. They kill every thing that moves.
Old Nov 6, 2013 | 05:25 PM
hawkgfr's Avatar
hawkgfr
I use one of those subsonic beeper thingies you plug into outlet...
This hasn't happened in the five years since.
Old Nov 6, 2013 | 05:33 PM
chasboland's Avatar
chasboland
I've had success (no problems) using Bounce dryer sheets in the engine bay and Irish spring soap along with moth ***** around the exterior. Obviously, setting a few Mouse traps underneath the vehicle will be quite effective as we'll. good luck.
Old Nov 6, 2013 | 05:44 PM
we zoom's Avatar
we zoom
I have used moth *****, puting them in a sock and placeing them around the car close to the tires. I have not had a proablm on the car or motorcycles.
Old Nov 6, 2013 | 05:51 PM
Rusler John's Avatar
Rusler John
I've used the Bounce dryer sheets for 2 years now and so far, so good. I lay them in the engine bay and in the car and they seem to work, plus, they leave a semi pleasant smell. I also put down a couple of bait bags near the garage door to keep them out. My house is in the woods, so, mice are inevitable, but, so far under control.
1911colt's Avatar
1911colt
The little bast ids did $850 damage to the wiring in my truck. The plug in deterrent was like a dinner bell...... No good... Drilled a bunch of holes in an Altoid Gum tin and loaded them with mothballs..Put in about 4 of them.Problem gone. FOR NOW
Old Nov 6, 2013 | 05:52 PM
Don-Vette's Avatar
Don-Vette
Stuff some old tube socks in the exhaust tips!! Sticky strips under the car and around perimeter of it. Seal all openings in garage.
Old Nov 6, 2013 | 06:02 PM
Joni Lynn's Avatar
Joni Lynn
I put out a few baited glue traps in my garage and they seem to go to those before seeing my C6 as a snack.
Old Nov 6, 2013 | 06:35 PM
budgreen3564's Avatar
budgreen3564
Go to a feed store and get some real rat poison. Keep pets away.
Old Nov 6, 2013 | 07:23 PM
z edge's Avatar
z edge
Old Nov 6, 2013 | 09:14 PM
c6vette142dude
Thanks for the ideas guys! Won't do the cats as I'd have to clean up after them. The poison may be an option, will be staying with my boss, not sure if there are pets, if so, the poison option is out. Soap, dryer sheets and moth ***** sounds like great ideas... cheap too!
Old Nov 6, 2013 | 09:33 PM
Cherokee Nation's Avatar
Cherokee Nation
Ak-47...
Old Nov 6, 2013 | 09:53 PM
c6vette142dude
Originally Posted by Cherokee Nation
Ak-47...
lol!
Old Nov 6, 2013 | 10:31 PM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Don't poison them, trap them instead. If they ingest the poison and die somewhere inside the car, the smell will get pretty ugly. Use snap or glue traps, this way you know you got them.
CSixDude's Avatar
CSixDude
peppermint oil works great.
Old Nov 6, 2013 | 10:53 PM
Aggie76's Avatar
Aggie76
I use the Bounce sheets like others and place some traps in the corners of the pole barn. Plus the -40 below temps do a good job since the barn isn't heated.
To re: Rodent deterrent
Old Nov 7, 2013 | 08:01 AM
truckplay's Avatar
truckplay
if you can keep the trash cans and antifreeze out of the garage it helps a lot. otherwise mothballs outside the car and drier sheets inside the car, plus it smells good when stored. there are ultrasonic GIZMOS you plug into the wall that are advertised but I have never used them. a cat will also work, but the little bastard is likely to walk on and scratch the cars
Old Nov 7, 2013 | 12:05 PM
2k Cobra's Avatar
2k Cobra
Had a cat! He watered my wheels down every night...
Old Nov 7, 2013 | 12:16 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
What keeps them away is Death.
Havahart traps outside the garage, followed by swim lessons.
Glue traps and snap traps all around inside the garage, but not in/under the car- don't want the bait attracting them.
Also, a Tupperware container with holes punched in the lid, holding a cupful of moth *****; one under each axle of the car.
Replace moth ***** every 3 months.
So far, no more chipmunk or mouse damage. But a modest number of dead critters.
They like dark places for nesting, so you might leave the hood open if storing the car for winter.
