Need Some Help!
Old Nov 8, 2013 | 12:26 PM
SWOOP10's Avatar
SWOOP10
Default Need Some Help!
2011 GS C6,,,,, Went to program my garage door in the visor and noticed i had no power, even on the lights so i check the fuse box on passanger side floor board and noticed the courtsey/lamps 10amp fuse is blown so grab another one and stick it in and it shorts! Great so i know i have a short somewhere, does anyone know where i should start? would a burnt out bulb somewhere cause this, I wouldnt think so but who knows? Anyone have a similar problem? Thanks
Old Nov 8, 2013 | 12:48 PM
Larry/car's Avatar
Larry/car
Burnt out bulb is an open and will not flow electricity. I would start with the courtesy lights, check the switches, look for broken wires. I don't know what else is protected by the fuse, try to isolate the various components until problem is discovered. Good luck.
