16290
Old Nov 11, 2013 | 10:30 PM
mtdriver's Avatar
mtdriver
Default 16290
I had 16290 miles on my original Goodyear run flats when I put my 2012 Grandsport away for the winter this weekend. Both fronts and rears are starting to cup pretty good so I think there will be new treads going on when the car comes out in the spring, probably Bridgestone run flats. From everything I've read, I think I did ok for mileage on the Goodyears but I'm definitely ready to get rid of them and get a different tire on the car. THINK SPRING!!!
PS - Thank to all the veterans out there for you service to our country.
Old Nov 11, 2013 | 11:19 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Originally Posted by mtdriver
I had 16290 miles on my original Goodyear run flats when I put my 2012 Grandsport away for the winter this weekend. Both fronts and rears are starting to cup pretty good so I think there will be new treads going on when the car comes out in the spring, probably Bridgestone run flats. From everything I've read, I think I did ok for mileage on the Goodyears but I'm definitely ready to get rid of them and get a different tire on the car. THINK SPRING!!! PS - Thank to all the veterans out there for you service to our country.
I have an '05 vert with Goodyears and I just bot an '11 vert with Bridgestone Potenzas. I am anxious to see/feel the difference.
Old Nov 11, 2013 | 11:34 PM
owc6's Avatar
owc6
IMO, the best thing you can do to maximize tire life is get an alignment EVERY every time you get an oil change, regardless which tires you put on your car.
lisa
Old Nov 12, 2013 | 04:03 AM
DJackman's Avatar
DJackman
lisa
Alignment at every oil change ?? you're joling right ?
Old Nov 12, 2013 | 08:10 AM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
For some, the oil gets changed once a year. That includes me.
Old Nov 12, 2013 | 08:48 AM
noz34me's Avatar
noz34me
Yeah, that's overkill. If you need an alignment that often, there's either a design problem with the car, or maybe you live in Pennsylvania where the potholes are prolific.
Old Nov 12, 2013 | 09:13 AM
cyclesailor955's Avatar
cyclesailor955
Default Bridgestone Potenza
I replaced the Goodyear Log Wagon tires on our 2011 Grand Sport with the Bridgestone Potenza run flat tires. It is amazing what four quality tires and alignment will do to improve the ride and handling qualities of a great car!!!
Old Nov 12, 2013 | 10:22 AM
owc6's Avatar
owc6
Originally Posted by noz34me
yeah, that's overkill. If you need an alignment that often, there's either a design problem with the car, or maybe you live in pennsylvania where the potholes are prolific.
d.c.
Old Nov 12, 2013 | 10:45 AM
mickey5's Avatar
mickey5
Do base coupes have the same alignment issues?
Old Nov 12, 2013 | 11:20 PM
mtdriver's Avatar
mtdriver
I had the car aligned to the Pfadt street specs when it only had 16 miles on it which I believe helped me get the mileage I did.
Old Nov 13, 2013 | 12:15 PM
cclive's Avatar
cclive
lisa
And the engine will last much longer if rings and bearings are replaced at every third oil change.
Old Nov 13, 2013 | 02:45 PM
ruxvette's Avatar
ruxvette
Good to know...thanks.
To 16290
