MGW Shifter question?
Old Dec 15, 2013 | 03:12 PM
  #41
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Originally Posted by dev1360
Do not reuse outer boot.
Put it in the box with the stock shifter parts. You won't need it unless you convert back to stock.
Old Dec 15, 2013 | 04:01 PM
  #42
NJZ06's Avatar
NJZ06
OK, cool.. Thanks for the feedback about the outer boot guys..
Old Dec 15, 2013 | 06:26 PM
  #43
garye's Avatar
garye
St. Jude Donor '12-'13-'14-'15, '21
Originally Posted by traderfjp
Hi,
I have an 08 coupe and the shifts are buttery smooth. Does the MGW give you the same smooth shifts but the travel is less between shift points?
I bought an MGW shifter and lower box for a 2011 GS and found the shifting not much different than stock. Shorter shift but not a $500.00 improvement.
Old Dec 16, 2013 | 08:36 PM
  #44
myfunz's Avatar
myfunz
Originally Posted by NJZ06
Quick question here.. I'm installing the newest MGW into my C6, I trimmed the shifter boot ring so that it tucks around the MGW bellows. What about the OEM outer boot that clips onto when using the stock shifter? I cant find anywhere online if that outer boots get's reused, if so I think it will have to be trimmed to get it to fit.
Can anyone who's installed the newest MGW in a c6 please provide some info..
Thanks..
Outer OEM boot are you referring to the boot attached to the center console?
Videos http://www.mgwltd.com/corvette_short...allation.shtml
Old Dec 16, 2013 | 08:50 PM
  #45
NormWild's Avatar
NormWild
So what exactly does the lower box DO? I have no issues with the current shift effort or vibration.
Old Dec 16, 2013 | 09:14 PM
  #46
NJZ06's Avatar
NJZ06
So there are 2 Factory Rubber boots, the one that bolts down with 4 nuts and then one that slips over the one that's bolted down. I was referring to the latter of the two.
Old Dec 16, 2013 | 10:02 PM
  #47
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
If you are happy with your current shifter than there is no reason to change.
I had the old MGW shifter and I liked it better then the OEM one for sure but I did have some slight vibrations at certain RPMs when accelerating hard.
With the newest MGW shifter and the lower box combo, everything is smooth and vibration free. That is JMO.
