My 2012 base coupe with 9000 miles just had an oil change and the dealer recommended I do an alignment due to slight uneven tire wear. From this forum I know you guys think this is important on these cars so I agreed and they are doing it now.
But my question is this - they also recommended a $300 fuel system cleaning, which I rejected at this time . They told me it should be done annually.
Complete rip off in my eyes .
Unless the owners manual indicates otherwise on the service schedules.
I drive my company car 55,000 miles a year so I see a lot of service bays - never have I had a fuel system cleaning.
If you have injector issues, bad fuel or some other cause for concern that would be a different story.
From: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Save your money. I feel I maintain my vehicles pretty well but I never do service just because I passed a mileage milestone or because it's been a year since the last time.
If the fuel system cleaning were a necessary maintenance action, it would be listed in the maintenance section of your owners manual - it isn't. If you have been using suspect gas or there is some other definitive reason to clean your fuel system, then consider it. Otherwise, just use good gas and perhaps a bottle of Techron annually and things will be fine and your wallet will feel better.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Whaddya think? Did I do the right thing?
If you have either a Texaco or Chevron station near you, run a tank full of their gas every now and then. It will do the same thing.
Wow -quick response, thanks. Looks like I made the right decision.
Do you all agree though, tht the alignment is a good thing to do?
Alignment, yes absolutely. Fuel system cleaning, not sure what they are going to do but just the process of taking fuel connectors apart could cause more problems than it is worth. Put a six dollar bottle of Techron in the tank a couple of times a year instead.
BTW...$300...wow, that's really funny. Ask them what exactly is done in that procedure, it would be fun to see what they say.
