I own and love driving my '10 Grand Sport Coupe. After about 14,000 miles, my front Michelins were worn out in the center (see photo). I believe that this pattern develops from over-inflating the tires, but I keep mine at the OEM pressure of 30 psi.
BTW, the rears, with the same mileage, still have sufficient tread to pass the state inspection.
Anyone have an idea what I need to do to get more uniform front tire wear?
-Clark
Reason: clarification/correction
From: Stafford VA, home of our wolf den. No house break ins to date.
if you are running OE 30 psi..cold...thats very strange...I run 32psi front and 30 psi rear, my OE tires are perfectly wearing at 15,000 miles. Do you do a lot of just highway cruising...ie: straight lines? The normal wear pattern for fronts is a slightly more worn left front outside crown edge due to the fact that the majority of turns you make are right hand turns... curious.....
based on Wolfdogs advise, started running 32/30 front/rear pressures 25000 miles ago in FWO's. Pulled tires and check tread wear and all tires are wearing consistently across the tread. Aligned for street use when tires put on 3 +/- years ago.
OP, not being critical of your methods or tools. however, it's possible that whatever tool you're using is out of calibration . I'd suggest getting a new one---doesn't have to be super expensive, just don't drop it.
I'd also suggest doing your tire pressure test first thing in the morning. and altho it may not be off by much, I wouldn't rely on the pressures in the DIC as accurate. 1 or 2 lbs. low on the DIC, 1 or 2 low by your gauge and you could be at 4 or more higher than normal.
and btw, where do you park your car when you take the tire pressure (indoor, outdoor, in sun, shade, etc.)?
I had the same thing on two separate sets of tires. Good year guy told me it was the nature of the beast with runcraps. If anything, I ran my fronts a little under inflated. Here is a pic of mine with 10,000 miles. Will see if this last set of non run craps do the same and then I will know.
I bought three different digital gauges and compared them against each other, the max variation was .5 lb so I suspect they are accurate.
Slightly overinflate the tires in the evening, then park the car in a garage overnight and bleed the pressures down to 30 in the morning.
