Can someone explain this ...
I got out, closed the Driver's door, walked around to the Passenger's side, tried the the door, locked. Even tried the hatch release button, locked. Went back to the Driver's door, tried the door, it was locked.
*I did NOT have my fob with me!
How or why was I able to open the Driver's door the first time?! Auto-lock setting is enabled / Horn sounds when lock is activated / lights flashFob was inside the house. When I retrieved the fob, everything operated as it should.
Anyone ever had that happen to them???
Elmer
AFAIK, the car will not relock after someone pushed the Unlock button on the fob.
Our Toyotas, going back many years, will wait a few minutes after the fob Unlock is pushed; if you don't open a door then they eventually relock.
Or as Rocketman said, could be a simple computer glitch.
Never turn your back on an electron.
Just a weird occurrence.
lisa
When you next approached the car without the fob, both doors were unlocked but you only tried the drivers side.
Then when you exited the car after the 'No Fob Detected' notice in the DIC, it Auto-locked both doors. The trunk/hatch is not affected by the status of the door locks.
lisa
It is, at least on my '12. I can open the trunk without fob and doors unlocked. But obviously not with doors locked.
lisa
If I leave the window down, lock the car, and reach in for the trunk button with no fob in my pocket; it's dead. Not sure if the button would work if I had the fob in my pocket outside the car.
My '06 Vert does not work that way. The fob must be at the rear of the car, near the antenna, to open the trunk using the rubber button above the license plate. Not sure why GM would change this and compromise security.
My trunk button on the dash does not work with the car unlocked unless the fob is in the front passenger compartment.
If the car is locked, the trunk button does not work with the fob in or out of the car. Alarm does not sound.
However, the gas door button always works.
