c6 2005 automatic
Old Nov 26, 2013 | 08:35 PM
Rivera9288's Avatar
Rivera9288
Default c6 2005 automatic
Have a C6 o5 Automatic I noticed that it doesn't go over 2000 rpms is this normal , it has power took it up to 120 mph but it just seems weird , I don't not have it in competition mode any ideas , it shifts fine will I think it does as it feels like its stuck in one gear and doesn't downshift at all
Old Nov 26, 2013 | 09:08 PM
TLS_Addict's Avatar
TLS_Addict
Sorry, but to go 120 mph you had to go over 2k rpms. Your post makes no sense.
Are you saying it wont go above 2k in any gears but OD?
Old Nov 26, 2013 | 09:12 PM
LMB-Z's Avatar
LMB-Z
" it shifts fine will I think it does as it feels like its stuck in one gear and doesn't downshift at all"
Does it shift or is it stuck in one gear? If it doesn't downshift, what gear is it in?
Old Nov 26, 2013 | 09:24 PM
OnPoint's Avatar
OnPoint
The Consigliere
Gonna need some more facts. Starting from a standstill accelerating up to speed, what exactly does it do? What does it do under hard throttle from a roll?
Old Nov 26, 2013 | 10:54 PM
owc6's Avatar
owc6
Yes, this post is puzzling, even if it was stuck in 4th, it would definitely get (a smidge) over 2000 rpms at freeway speeds. Anything over 80 would be considerably higher.
If you don't shift "manually" it will still go from 1-2-3-4 in D. And when you decelerate, it won't noticeably "downshift" when in D. When you come to a stop (or near) it should engage a lower gear to accelerate.
lisa
Old Feb 27, 2014 | 09:54 PM
stevep69's Avatar
stevep69
Default Did you ever get it fixed?
Did you ever get this resolved? My vette does the same thing. It feels like it starts in 3rd or 4th. It wont downshift or start in 1st even if I put the shifter in first.
Old Feb 28, 2014 | 02:57 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default The band might be broken.....
The band might be broken.....or a leak in the servo....
Just happened to my tahoe.
Or a shift solenoid....
Checking the condition and level of the fluid would be first.... Then check codes.....
Call me if you're stuck.
A4 is a great trans in 2005.... Round here, We make em SING!
914-332-0049
Chuck CoW
Old Feb 28, 2014 | 12:30 PM
Rivera9288's Avatar
Rivera9288
hello all the band was broken all good now
thanks Chuck for the input much appreciated !!!
Old Feb 28, 2014 | 01:06 PM
EVRose's Avatar
EVRose
Did a dealer repair it? What was the cost?
Old Feb 28, 2014 | 01:22 PM
1rusty1's Avatar
1rusty1
914-332-0049
Chuck CoW
I have to ask since I repeatedly hear negatives about the 05 auto trans and rear diff. What do you like about the A4 since that is what I own. I am glad to hear something positive about them for a change!
Old Feb 28, 2014 | 01:41 PM
Justasheet's Avatar
Justasheet
The A4 is fine. The diff is the issue if you race And have a manual trans. Wheel Hop is the culprit.
Jeff
Old Feb 28, 2014 | 02:36 PM
tennblkc6's Avatar
tennblkc6
Old Mar 4, 2014 | 03:29 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default The A4 is a great trans if you tune it right.
The A4 is a great trans if you tune it right. You would never know it from the way it performs stock,
but a good Chuck CoW TUNE wakes em up night and day.
Chuck CoW
Old Mar 6, 2014 | 07:58 AM
Don 79 TA's Avatar
Don 79 TA
Chuck CoW
I concur..
the wife loves the way the trans is shifting in her 05 now
certainly made an improvement
still have more datalogs to make, but certainly much more improved
Old Mar 7, 2014 | 02:32 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Cool thing is.....
Originally Posted by Don 79 TA
I concur..
Cool thing is.....The A4 tune is great, but when you add CoW BOOSTER! is also makes very
positive improvements to the way the trans behaves (without further trans tuning) because the
A4 and A6 transmissions shift behavior is modified by how much the driver presses on the throttle.....
Pressing the throttle MORE tells the trans you expect more... Funny thing is that the CoW BOOSTER!
gives you soooo much more when you press much less that it actually has a favorable effect on how and
when the transmission shifts.... Extra bonuses for FREE!
I love it!
Chuck CoW
To c6 2005 automatic
