Front Zo6 Conversion
Nov 26, 2013 | 09:29 PM
When doing a Z06 wide Body Front on a Base C6 there is a space left in the fender liner . There has been articles on using a reinforced rubber strip to fill that space, has anyone made a pattern for this strip. And what are the reinforced rubber specs for making the filler strips ?? Thanks
Nov 27, 2013 | 01:11 AM
St. Jude Donor '11-'12-'13-'14-'15
You can buy fiberglass fender liner extensions that glue in for $100 for the pair from SS-Vettes, and they are a perfect fit.
They also make a wide fiberglass fender liner that is much cheaper than OEM.
I know this doesn't answer your question but, IMHO it's a better option.
Nov 27, 2013 | 10:28 AM
Quote:
Originally Posted by
**** Jockey
Nov 27, 2013 | 11:24 AM
2016 Corvette of Year
2015 C6 of Year Finalist
I bought the inner fenders from SS-Vette
You can see them glued on in the below pics
Nov 27, 2013 | 11:45 AM
2015 C6 of the Year Finalist
Here's the other option.
Added some epoxy to the top join so I could cut off the fender edges (hidden) so the wider tires wouldn't rub.
I got the fender wheel wells as well but ended up selling them.
Nov 27, 2013 | 08:34 PM
Thanks **** I will look into it
Definitely like the small glue on strip as far as ease of installation . Thanks for the info Guys..
Nov 27, 2013 | 09:31 PM
Premium Supporting Vendor
I know Corvette Recycling makes a kit for around $100 as well. It finishes everything off nicely.
Nov 27, 2013 | 09:50 PM
Gene Culley
Last I heard, they no longer sell that item.
That is where I got mine though.
Nov 27, 2013 | 10:00 PM
ncvette_1FUNRIDE
Oh ok, my bad, sorry!
Nov 27, 2013 | 11:42 PM
looks like I got lucky got a pair from them awhile back.
