Another question...
Old Nov 27, 2013 | 09:42 AM
Perfesser's Avatar
Perfesser
Cruising
Default Another question...
I have studied the Corvette Black Book repeatedly, but can not figure out if the C6 Vettes still have run flat tires....pardon my ignorance, but I have been out of Vette circles since 2002. I remember they were a pain because then the tire guys needed special equipment, and a flat/puncture was really, for the day, expensive, much less mounting aftermarket or OEM chrome wheels if my C5 wheels were upgraded. Any help will be appreciated. Away too long....
Old Nov 27, 2013 | 09:46 AM
Vette_DD's Avatar
Vette_DD
Yes, C6s have had runflat tires since the first '05 came off the line in 04. They still had them on my '012, so I guess the '013s had them.
Old Nov 27, 2013 | 09:48 AM
4SUMERZ's Avatar
4SUMERZ
The C6 does come with only runflat tires. Because they have become much more prominent in the car industry, most all tire shops can work on runflats, although if you talk to the tire guys, because of the rock hard sidewalls, they are a pain to take off and put on rims.
C6 owners either stay with the runflats, or for numerous reasons, install non runflat tires.
Old Nov 27, 2013 | 09:56 AM
Perfesser's Avatar
Perfesser
Cruising
Thank you...I just rechecked the Black Book for 2005 and got the answer. Should have known, but it doesn't hurt to be sure. Again, thank you for your help. Been away too long!!
Old Nov 27, 2013 | 09:58 AM
smurfkiller's Avatar
smurfkiller
from the factory they do . many of us prefer to replace them with non run flat tires.
Old Nov 27, 2013 | 10:08 AM
Cherokee Nation's Avatar
Cherokee Nation
Most GOOD shops like Firestone have the new tire machine ( ROBOT) thats removes the tire in seconds...
Old Nov 27, 2013 | 10:09 AM
dvilin's Avatar
dvilin
Old Nov 27, 2013 | 10:51 AM
Perfesser's Avatar
Perfesser
Cruising
What do you do in case of a flat on non EMT tires and no spare? Like the old C5 solution- use a tire inflator/whatever you call the punture sealer spray on the version they sold for a while that was called, I think, a Hardtop? Kind of like darned if you do, and darned if you don't. Had a tire guy tell me a couple of weeks ago that it would be $200 plus or minus to repair a flat run flat tire. Golly gee- I am old enough to remember the good old days of buying a inner tube repair kit for 59 cents from the corner gas station and fixing a flat myself with what we called a tire iron, sweat, and leverage, using a bumper jack(on my first car-a 53 Nash Rambler convertible -living large for 1963!!
Old Nov 27, 2013 | 10:59 AM
unixcorn's Avatar
unixcorn
I choose to keep runflats when replacing but I do go with Michelins rather than the stock GoodYears. I have read here that many who do choose to go with non-runflats keep small compressors in the cubbys under the back hatch. Also a plug kit for a temporary fix. Your friend who told you it's $200 (half the cost of a new tire) to fix a runflat is way off. Most here quote $20-$50 for a repair. Also, since the tires are Z rated, repairing a Corvette tire should be done properly and carefully. If the puncture is too close to the sidewall or has cut a cord the tire shouldn't be re-used. Just my two cents.
Old Nov 27, 2013 | 11:22 AM
Perfesser's Avatar
Perfesser
Cruising
I agree- I am sure he was interested in selling a new tire rather than repairing a flat- hypothetically, because I only mentioned it in a conversation I had while a regular tire was being repaired.
Old Nov 27, 2013 | 12:05 PM
bonnell's Avatar
bonnell
I kept run flats on my C6s (and will continue to do so) but my C5 had non run flats and I carried the Continental Conticomfort Kit. I never had to use it so I can't comment on how well or how fast it worked.
http://www.tirerack.com/accessories/detail.jsp?ID=38
Old Nov 27, 2013 | 12:15 PM
icntdrv55's Avatar
icntdrv55
What do you do in case of a flat on non EMT tires and no spare? …. Golly gee- I am old enough to remember the good old days of buying a inner tube repair kit for 59 cents from the corner gas station and fixing a flat myself with what we called a tire iron, sweat, and leverage, using a bumper jack(on my first car-a 53 Nash Rambler convertible -living large for 1963!!
I've done this, too, on cars of old and still do on my motorcycles. I SURE AS HE11 wouldn't want to try it that way on the Vette's $600 12" wide alloy rims with a RFT 30-series tire!!!
Old Nov 27, 2013 | 12:40 PM
Luke@tirerack's Avatar
0Luke@tirerack
Former Vendor
St. Jude Donor '11-'12
see this thread in the wheel and tire forum
http://forums.corvetteforum.com/whee...ire-fixes.html
Old Nov 27, 2013 | 02:22 PM
Perfesser's Avatar
Perfesser
Cruising
Oops= forgot about the tire pressure sensor!! The fixaflat would probably ruin that too.
To Another question...
