Not sure if this has been covered before,in my 08, the dash lights come on sometimes right away and sometimes they come on a half hour later or longer, doesn t matter the outside light, if they don t come on it is hard to select radio channels or see the guages. Any ideas ? When i had it at the Stealership a few weeks back, of course it wouldn t do it, and the lad said, hard to check anything when it is not happening.
Any input would be appreciated.
they are not "coming on" after half an hour - they are on but dimmed because your headlights are probably automatically on - next time get out and check, or alternatively your dash will have the headlight symbol on
the drl are always on, today i drove it for 30 minutes,and all of a sudden they came on, the outside lighitng did not change tho.
My 07 was like that. I would rotate the lights switch
toward me. Turned off lights. DIR would "Headlamps Suggested". It was a Z06 if that matters. My '13 Z06 does not do this.
