mid pipe question
i have pfadt headers on my car with 09+ x pipe high flow cats and a set of npp mufflers from 2011 with the valves wide open all the time i love it. sounds great.
LS7 Manifolds
LS7 Cats
LS7 mid-pipe
LS7 mufflers or 3" to 2.5" reducer and use your 2.5" NPP system which with an A6 makes it a total bolt in.
The only things you have to worry about clearing the A6 in your car are the LS7 over axle MUFFLER pipes if you use the LS7 MUFFLERS. ANY DECENT muffler shop can mod (aka DIMPLE) the muffler pipes to fit. If you don't want any pipes dimpled, put the damn reducers on the LS7 midpipe and use your stock UNMODIFIED NPP mufflers.
In this pic you can see the end of the midpipe is welllllllllllllllllllllllllllllll before where there is any interference with the transmission.
:will y:
I looked at this picture also but I think not. I will probably start mine this weekend.
LS7 Manifolds
LS7 Cats
LS7 mid-pipe
:will y:
LS7 Manifolds
LS7 Cats
LS7 mid-pipe
:will y:
where do you install the reducers to make it a bolt on install with this configuration?like I said I have zo6 mufflers off a 2008.right now I have a diablo tune in the car.i have read both ways to do it,keep my mufflers and reduce or go with z06 mufflers.if I go with the z06 mufflers I will do the muffler mod.
Sorry, but based on your continuing questions....
- Install everything but the mufflers. The midpipe will be secure via the studs/nuts to the cats and it has an aft hanger.
- Drive the car to a shop (obviously coordinate in advance). Yes it'll be loud but tolerable due to the cats
- Give the shop the Z06 mufflers (which tuck nicely in the cargo area with some towels to protect everything), and the hangers and tell the shop to install them
- They will dimple the over-axle pipes as needed and have the car done in an hour and for probably less than $150.
$60k+ car and you're hand-wringing over pennies by your refusal to take it to a place that knows what they're doing.
I getting ready to get in my car and drive over and do it myself.
Where are you located? I'm currently in SoCal.
