help with scrapping bottom
Old Dec 25, 2013 | 03:07 PM
jtw17's Avatar
jtw17
Default help with scrapping bottom
I am the new proud owner of an '08 vert. Upon entering my driveway, i am scrapping the undercarriage. The slope is subtle, and seems to be worse backing in or out. Any advice would be appreciated..... I will get pics up shortly.
Old Dec 25, 2013 | 03:10 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Move.
Seriously, has the car been lowered? A subtle slope may scrape the front air dam and it is usually harmless...'cept for the embarrassment.
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
It's the air dam rubbing. It's normal and made to rub. Drive it and don't worry about it.
Old Dec 25, 2013 | 03:16 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
The air dam under the nose is actually 3 separate pieces,
At less than $100 it's almost sacrificial and rubbing/scraping is normal.
If you can, try approaching your driveway at an angle.
Old Dec 25, 2013 | 03:19 PM
heli-vette's Avatar
heli-vette
New tires , sway bar bushings , maybe 1/2 " on the height adjustment . Can get a bit more height . Like others wrote ,dragging the nose is common ,its even in the manual . Try hitting the driveway at a slow 45 degree approach , sort of flattens the ramp .
Old Dec 25, 2013 | 03:41 PM
Steve_R's Avatar
Steve_R
Why install new tires, bushings, or raise the car for something that's normal and does no damage???
Old Dec 25, 2013 | 03:57 PM
heli-vette's Avatar
heli-vette
It's the degree of scrape , every dip or driveway . Or a few times a day .
I don't like to bounce the frame on the pavement . They make a kit for it Fangs / frame covers .
Old Dec 25, 2013 | 04:04 PM
Steve_R's Avatar
Steve_R
If your frame is hitting the pavement - ever - you have a serious problem. That's not what the OP is asking about. Scraping the air dam is common and even mentioned in the owner's manual. There's no need to adjust, replace, or change anything for that.
Old Dec 25, 2013 | 04:13 PM
jtw17's Avatar
jtw17
[IMG][/IMG]
Thanks so much for your responses, you were all right. The air dam was scraping, no big deal. Had my wife lay on the ground in the driveway while I backed out. Again, I appreciate everything.
Old Dec 25, 2013 | 06:04 PM
Grok's Avatar
Grok
A very wise man indeed, just look in his garage.
Old Dec 25, 2013 | 06:51 PM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
do a web search for driveway curb bridge, (bridge spelled with a j instead of a g) . I"m going to order one in a few days.
Old Dec 25, 2013 | 07:10 PM
Richard Ames's Avatar
Richard Ames
Can you enter at an extreme angle? That can help .
Old Dec 25, 2013 | 07:28 PM
Tony 327's Avatar
Tony 327
Seriously, do you think the cops are gonna believe that!?
Old Dec 25, 2013 | 07:31 PM
Richard Ames
Life is full of missed oppturnities
Old Dec 25, 2013 | 08:35 PM
EVRose's Avatar
EVRose
......Had my wife lay on the ground in the driveway while I backed out. Again, I appreciate everything.
If I had seen this thread a little earlier this might have stopped her from having to do that.
Old Dec 25, 2013 | 11:44 PM
Larry Myers's Avatar
Larry Myers
[IMG][/IMG]
What a guy. lmao
Old Dec 26, 2013 | 07:30 AM
BostonJoel's Avatar
BostonJoel
www.bridgit.com
To help with scrapping bottom
Old Dec 26, 2013 | 08:19 AM
Boomer111's Avatar
Boomer111
I always scrape backing out and never driving forward, on the home driveway.
No matter what angle I take backing out.
Neighbors always look, as if I am destroying my car...
Old Dec 26, 2013 | 08:21 AM
Don-Vette's Avatar
Don-Vette
Just don't drive without one,because if you do and then hear any scraping ,it ain't gonna be pretty.
Old Dec 26, 2013 | 08:51 AM
Red08's Avatar
Red08
I have a drive way with a steep slope. I come in from one side rather than hitting it straight on and it helps.
