frustrating....
Old Jan 14, 2014 | 11:51 AM
cclive's Avatar
cclive
If the driveway is wide enough to enter at a high angle, it is almost always possible to avoid scraping. If you think of entering straight as 0 degrees, try coming at it at more than 45 degrees until both front wheels are on the driveway, then turn straight into it.
Old Jan 14, 2014 | 05:34 PM
Cherokee Nation's Avatar
Cherokee Nation
Originally Posted by tennblkc6
hmmm...I dunno . I gather you haven't had any issues with high temps in the hot summer months but the air dams on most cars help direct to the radiator to assist with cooling. not sure about the vette tho. but I'm sure gm put it there for a reason...what that reason is I'm not sure of.
No Sir:In the summer months we have temps over 100 degrees for months & my vette runs in the mid 190s & in traffic it will go to 205 or so.If you have the June issue of Car and Driver mag. GM said that they made a change on the C7 because the design on the C6s didn't work that well..? There are some guys on this forum that removed them & did not see a temp change...
Old Jan 15, 2014 | 09:52 AM
2vettes's Avatar
2vettes
Originally Posted by VET4LES
Mine's been scraping since April 2005 and still looks like new.
Ditto since February 2005. It doesn't scrape going in; just backing down and out. Other than the noise, there is no problem.
Old Jan 15, 2014 | 10:28 AM
Speedforhire's Avatar
Speedforhire
Originally Posted by Steve_R
The air dam is a wear item. The Owner's Manual even says so. It's $100 or so to replace it. Given all that, why do so many Vette owners go to great trouble or expense to "fix" it? I don't get it.
.........you hit the nail on the head..........
Mine scrapes all the time while traversing my driveway entrance and I don't lose a minutes sleep over it. It's an expendable piece that costs less than $100.00 to replace when bought from our superb venders here on the forum.
Old Jan 15, 2014 | 10:31 AM
Speedforhire
ditto.........this works for me............
Old Jan 15, 2014 | 08:42 PM
Cherokee Nation
The corner 2 are easy to replace,but the center one you have to use ramps or a jack..PITA......
Old Jan 15, 2014 | 10:28 PM
tomtoro's Avatar
tomtoro
I scrape my gs when I go into my folks driveway (once a week) and it kills me, but I'm not leaving it on the street. When I inspected it, it wasn't damaged so I keep doing it.
I keep mine at a cottage up north and the short gravel road leading up to it has ruts six inches deep because of the garbage truck. I have to prepare the road with a rake and shovel each time so the gs won't plow the gravel too deep. Folks there think I'm real charitable and wave while I work, LOL!
Old Jan 16, 2014 | 08:33 PM
dbirdhouse1's Avatar
dbirdhouse1
Default You've hit the nail on the head for me
Originally Posted by Torchsport
Mine actually broke the center piece where the center bolt goes in. So mine has a permanent gap. But I'm the only one that notices it.
I'm in search of some heavy duty double stick tape. I think member Digital Widgets did the same thing.
yup, the same for me
dbirdhouse1
Default thanks guys for replying
you've helped me vent on this, I'll keep at it
Old Jan 16, 2014 | 08:44 PM
JC23GS10's Avatar
JC23GS10
Originally Posted by dbirdhouse1
listening to my under spoiler being ground up on the dip at the bottom of my driveway.....I have tried hunks of plywood, even built up a couple of pieces using my amateur hwy engineering skills to try and lift the front end enough as I backed out...but to no avail....just have to get used to the noise of it being slowly scraped up.....ah well, small price to pay for such a great vehicle.....
Yeah mine scrapes all the time as well.... found that if you back out on an angle as much as possible it's a lot better
Old Jan 21, 2014 | 05:58 PM
benwinrich's Avatar
benwinrich
Not sure how much slope you have but I bought some new ones and cut them right at the curve as they go down and under and haven't had a problem yet.
