Ipod hook up
Old Feb 1, 2014 | 08:23 PM
98vetteguy's Avatar
98vetteguy
Default Ipod hook up
need to know best way to install ipod connection?2008 with nav
Old Feb 1, 2014 | 08:33 PM
spdkilz911's Avatar
spdkilz911
I have the GM PAL 2. It works ok. I am just going to upgrade the head unit. I should have done that from the start
Old Feb 1, 2014 | 09:06 PM
NVR LAT's Avatar
NVR LAT
Please forgive me for not remembering the name...
I bought a wiring harness from the same guy that was selling the "PAL" units. I couldn't use the PAL because I had switched my radio to Sirius and PAL didn't work (I know, they're the same - they weren't then). The harness just plugged into the car back at the XM/Sirius Box. It was simple, then ran the wire up to and under the console, then drilled a hole for the plug. In the long run, I think I'm happier with this than the PAL.
I just can't remember his name, I'm sure someone will. If I can remember, I will re-post.
Old Feb 1, 2014 | 09:20 PM
NVR LAT's Avatar
NVR LAT
Here's a pic of the end result...The silver plug on the side of the console is it. It works fine...
Name was (maybe) "kawal" (here on the forum), not sure though.
Old Feb 1, 2014 | 10:04 PM
Kvothe's Avatar
Kvothe
Ray Kawal. He has a couple options that can work for you. Here's his website:
http://www.kawal.net/vettemods.htm
To Ipod hook up
