Cold Air Intake
Old Feb 6, 2014 | 10:20 AM
C8-Vette's Avatar
C8-Vette
Default cold air intakes
My friend installed a supercharger and gave me his (Breathless performance). For nothing it was a great buy. A cold intake alone with no other mods is useless, you gain nothing. The only change is a reduction to net worth of $500 or so.
Old Feb 6, 2014 | 10:41 AM
FireGS's Avatar
FireGS
I just put a used Halltech mf103 on mine. I cant tell any difference but it did reduce my best 40-60mph time to 1 second flat from my previous best of 1.1 with just the headers. I bought it because it is suppose to help surging when you get a cam. I will say it keeps the IAT down a few more degrees than stock did. My MAF readings on the torque app are very high now compared to stock also.
Haven't been to the track yet to get a 1/4 time. I would say if you find a used intake it is almost worth it if you are doing other mods. at $500 save your money
Old Feb 6, 2014 | 10:45 AM
Dewayne'sZ06's Avatar
Dewayne'sZ06
Originally Posted by Steve_R
I'd guess 29 HP was from the tune, with maybe 1 from the Vararam.
Very,Very Possible..but I Like it
This is the dyno readings prior to the Vararam and after Vararam plus the tune
Old Feb 6, 2014 | 11:04 AM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
Try to locate a used Halltech Super Bee II and beehive. I ran one for 4 years on my Z06 and was very happy with it, no problems. Sound was better and butt dyno felt better so I think it was worth a few hp. No matter I wanted one and was happy with it. Considerable bad press on the forum for Vararam, poor quality, water ingestion, etc. Do a search.
Cherokee Nation's Avatar
Cherokee Nation
Originally Posted by 1rusty1
I surprised that a K&N A/C or any other would require a new fuel/air ratio. Was that your only MOD to the engine or did you also add exhaust? I am also thinking of changing my A/C but don't want to mess with a new tune.
No:I put the K&N on & about a year later i had a cam installed & then had it tuned.It ran great with just the K&N without a tune,no problems with the Air/fuel ratio.Like many have said the ECM will ajust for it...
Old Feb 6, 2014 | 11:24 AM
Cherokee Nation
Originally Posted by Paolo01
Thinking of adding a cold air intake to my 09 C6 (LS3). Any recommendations? Which have you installed?
Check out the Blue Attack filter for your stock intake before you spend a lot of $$$$ on a complete systrem....
Old Feb 6, 2014 | 11:28 AM
pahlbfishn's Avatar
pahlbfishn
Originally Posted by nykbob
I went with the K&N. No complaints here. Not sure about colder air helping performance, but I have always wanted my vehicles to breath better. Sounds slightly better than OEM.
Your engine will breathe SLIGHTLY better but will suck in more dirt.
Old Feb 6, 2014 | 11:30 AM
pahlbfishn's Avatar
pahlbfishn
[QUOTE="Dewayne'sC6;1586102488"]I went with the Vararam CAI and had a tune and picked up 30hp with the combo. Very pleased with mine [/QUO
Was that 30 hp verified on a dyno?
Old Feb 6, 2014 | 11:33 AM
Mike's LS3's Avatar
Mike's LS3
At closed loop (cruise) the ECM will adjust the fuel trims and add more fuel to compensate for additional airflow. However, positive LTFT will carry over into open loop (WOT) were the A/F values are set in the tune. The stock tune A/F is already rich, now more fuel has been added. Yes, the CAI might increase air flow, but it's only guess work until it's tuned. Some CAI's are designed with this in mind and change the MAF read area to compensate. To optimize any change in fuel metering a tune is needed.
Old Feb 6, 2014 | 11:51 AM
HOXXOH's Avatar
HOXXOH
Originally Posted by BWF07
First off it is not drawing in the air from outside the engine compartment it is not a true cold air induction system. Next the only way to know the true HP gains is to do a dyno run prior to the install then again after it is done. If all you want is for looks at shows and cruise in there are plenty of after market air filter systems out there. So look around.
If you are looking for a performance gain go with the Vararam, but if that is all you are doing, I don't think you will notice much.
Regardless of any HP gains or losses for a CAI shown on a dyno, they don't directly transfer to gains or losses on the street.
The only way to measure power differentials anywhere close to accurately is at the dragstrip. There are even variables with that method which must be accounted for and compensations made.
Dynos are tuning tools that record power at WOT. Anytime you're at WOT on the street, your butt dyno calibration is in direct relationship to your expectations from the cost of the mods.
Old Feb 6, 2014 | 12:18 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Default No dog in this fight, just my $.02
I took a Z06 intake and modified it into a "CAI". On my "stock" GS my best went from 12.31 to 12.01. My car drove, idle, etc., the same as when I bought it. I'm sure most have seen my modified Z06 setup. If I were to "buy" an aftermarket CAI the one below reminds me of how mine is setup which works pretty well for "me". Because of where the filter is located with no snorkel going to it the one below is a lot less likely to suck up water IMO.
PS: Oh, and any other "bolt-on" LS3's (including the lighter narrow bodys) with the "same" type of mods. i.e. Headers, CAI, Tune & Tires on the C6 fast list all fall in behind me in both ET & "MPH". I'm sure a lot are running the big HP snorkel intake.
http://api.viglink.com/api/click?for...%20-%20YouTube
Old Feb 6, 2014 | 12:28 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
I'm curious, were atmospheric conditions the same for both runs, particulary ambient air temp?
Old Feb 6, 2014 | 01:11 PM
  #33
C7/Z06 Man's Avatar
C7/Z06 Man
I "feel" the conditions were close. I do not have a weather station. The runs were within a week or so of one another.
The reason that I made the CAI modification is because I went out in the third round running for a "Wally" (pi$$ed me off ) due to the sensor retarding the timing from underhood heat.
Old Feb 6, 2014 | 01:21 PM
  #34
Dewayne'sZ06
Yes sir..Before and after... The Dyno is posted 5 posts in front of your post
Old Feb 6, 2014 | 01:25 PM
  #35
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
I did it for looks only......no performance or mileage gains to noted. After all, the rev gage rarely goes over 3K.
Old Feb 6, 2014 | 03:09 PM
  #36
corvetteflier's Avatar
corvetteflier
After getting a very slight surge ~60-65mph in 6th with the stock intake and propped open shroud on my '13, I decided to research what is out there. The Hitachi MAF is much more sensitive to turbulent air than the old style. On my '06, a K&N Aircharger and propped shroud worked great. Not so much with the new MAF. Anyway, I bought the newest Halltech MF105S Wednesday after talking with Jim Hall. Dyno results show 15+ rwhp and the IAT within about 5 degrees of ambient under way. The Beehive shroud covering and protecting it from underhood temps is a great idea. It appears that the engine will lean considerably, important here at 7000' where the stock runs very rich--especially under wot. GM Performance did a dyno run which showed a solid 15hp gain, as well with the older 103 version. Will give some feedback once I get it installed. They aren't cheap, but I did a lot of research before spending the money and everything leads me to believe it was the right choice. With Bullets and the Halltech, I feel it will easily add 30-35 crank hp. Coincidentally, just what the C7 with NPP makes--and 200 pounds lighter on my narrow body. There is a lot of hype on bolt on adders for hp, but the Halltech and the B&B Bullets back it up with hard numbers and reviews from respected sources.
Old Feb 6, 2014 | 03:49 PM
  #37
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Originally Posted by 08C6
Have the Airaid installed ...Fit & finish excellent !!!
The Airaid system MUCH improves the stock air intake systems on LS1 and LS2 engines. Not so much so on LS3 and up engines. The LS1 and LS2 systems were much more restrictive than the later systems.
Tom
To Cold Air Intake
Old Feb 6, 2014 | 04:06 PM
  #38
budgreen3564's Avatar
budgreen3564
Only "performance" mod
Old Feb 6, 2014 | 04:24 PM
  #39
Flh Den's Avatar
Flh Den
Veteran: Marine Corps
St. Jude Donor '13 thru '25
My08 had a Halltech on it when I bought the car so I can't tell you about before and after results, but the car runs perfect with it.
Old Feb 6, 2014 | 05:07 PM
  #40
hawkgfr's Avatar
hawkgfr
The only different between the Z06 & the LS3 is the silencer box on the LS3.
zactly....
