Screwed or what?
Old Feb 10, 2014 | 04:51 PM
bahamabum's Avatar
bahamabum
Shake the car hard! Hopefully wake one of the FOB's!!
Old Feb 10, 2014 | 05:02 PM
R&L's C6's Avatar
R&L's C6
Originally Posted by LMB-Z
This is going to sound stupid and crazy, but trust me, it works. Ask me how I know.
Remove outboard driver side rear tail light (1 screw at the very top of the tail light). Let it hang (put a towel between the light and car to keep from scratching car). Drill a small hole left of center through the back of the car. Its only carpet and backing plus rear of car and will never be seen again.
Take a clothes hanger and put a small bend on the end. Have someone with a flashlight stand at the passenger side front windshield and shine the light on the door pull in the rear compartment. Grab the pull with the clothes hanger and pull. Drivers door will open.
Mat down carpet where the hole is and put some black silicone on the inside where the tail light goes to fill in the hole. Replace tail light. Done.
If you have any questions, feel free to call me 903-490-6010. I will be glad to help.
Very inventive and you just gave me an idea for a little spring time mod. I think I will attach a cable to the pull and route it behind the taillight for an emergency such as this.
Old Feb 10, 2014 | 06:12 PM
VET4LES's Avatar
VET4LES
Good idea. Since I lock my doors with the fob this will never happen to me. In addition I have a key hidden under it.
Old Feb 10, 2014 | 06:32 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
First, what makes you think both fob batteries are dead. Just because they are inside the locked car doesn't mean the doors can be opened from the outside.
You can take the VIN to the dealer and they can cut you a key. However, unless they know you, they will want some kind of proof of ownership, which may also be in the car.
The key may be a bit pricey, but you would have a spare that you can hide on the outside of the car.
The coat hanger through the trunk is a clever option, hopefully your pull-tab isn't buried too far under the carpet.
Unless OnStar is already activated, they can't help.
It has also been posted that some locksmiths have fished in through the door window and snagged the emergency pull lever on the floor next to the seat.
Good luck.
Old Feb 10, 2014 | 06:44 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
If not a AAA member just call a reputable tow outfit. They can come with their air-pumped wedge and slide it between the window top and the body, put a little air in it, slide a wire down inside and grab the emergency release on the floor. Works every time. No, it will not damage the window or the track.
Old Feb 10, 2014 | 07:02 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
That's a good one Reggie, I'll have to remember that, and I will not leave any of my 8 track tapes in the Vette when you are around.
Old Feb 10, 2014 | 07:07 PM
haljensen's Avatar
haljensen
Originally Posted by garye
OK lets get this out of the way right off the bat, I’m a dumb azz. Now we can move forward. Both my key FOBs are in my 2011 vette and evidently the batteries went dead on both. The car is locked and the doors securely shut. So, now what, go to the dealership and purchase a new key FOB, anyone have an idea of what they cost? Thanks for any advice, it’s a mistake I won’t make again.
Since it's February in Minot you won't be working on the car the car outside. New fobs won't do you any good, the batteries are probably OK but they are designed so the car is locked if the fobs are inside the car. You need a key. Your best bet is to take proof of ownership (Title with VIN) to a GM dealer and have them get the key code to cut a key. Use the key to open the rear hatch, pull the tab to open the door and retrieve your fobs.
Might be expensive but nothing gets damaged doing it that way.
Old Feb 10, 2014 | 07:10 PM
berk4422's Avatar
berk4422
Originally Posted by Rich Mickol
Dealership and have them cut a key. Go in through the rear hatch. Once inside turn off the auto locking feature so this won't happen in the future. Good Luck
OP, I went to the dealer with my registration card and a blank uncut key. By using my VIN number he cut a new key in 5 minutes. free
Just go to the dealer with proof of car ownership/vin number and they will cut you a new key. Very easy and cheap...
Old Feb 10, 2014 | 07:16 PM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
FYI: If you are willing to wait a few days to save alot of money in this situation.
The key (blank) does not cost triple figure dollars... can be found online on fleabay for under $10 a piece. The option of overnight mail is an option which wont be astronomical either.
Take that blank key to a reputable GM dealer with your VIN and proof of ownership (insurance/title) and have the key cut for a nominal fee... resulting with an emergency spare key.
Old Feb 10, 2014 | 07:33 PM
phileaglesfan's Avatar
phileaglesfan
Good luck.
Go on line, get a copy of our insurance card. That should be all the proof you need.
The other route is the break in procedure above, which I'm sure thieves probably know already. I definitely wouldn't leave a pull cable outside just in case.
Regardless, once inside turn off active locking or whatever they call it. Pushing a fob is a real easy task. Sometimes automation is not good.
Old Feb 10, 2014 | 07:36 PM
dbirdhouse1's Avatar
dbirdhouse1
Default best solution
Originally Posted by C6Warrior
Join OnStar and have them pop them open. Problem solved
Old Feb 10, 2014 | 08:01 PM
Cherokee Nation's Avatar
Cherokee Nation
If he has no paper for proof ownership,all they have to do is run his plate..( If He Owns It)......
Old Feb 10, 2014 | 08:08 PM
  #33
Cherokee Nation
A friend of my works for Pop Of Lock & one nite down at the bar i asked him if he could open my hatch just for the heck of it.It took him maybe 30 seconds to open it.The alarm went off as expected.
Old Feb 10, 2014 | 10:45 PM
  #34
cclive's Avatar
cclive
The batteries in the fobs are not necessarily dead. It is not impossible to lock both fobs inside the car. Go to the dealer with proof of ownership and the VIN and they can cut a metal key from that number. Another fob will not be of any help as the car must be programmed to accept it and you can't do that from the outside.
Old Feb 11, 2014 | 08:55 PM
  #35
garye's Avatar
garye
St. Jude Donor '12-'13-'14-'15, '21
wow, you guys are great, lots of good advice and no one challenged my mental capacity. Well I suppose ya’ll want to know what happened. Called AAA guy came out and had a jimmy and a long rod with a curved end. When I explained it was an electronics lock he said I can’t get that open, sign here saying I was here. i called the chevy dealership and they said bring in proof of ownership, we might be able to make a key but it’s going to cost you. The next day I told my wife I was going to the dealership to get a key made for the vette. She said why, I told her I locked them both in the car, she laughed and said I saw both of them in the cup holder so I grabbed one and then shut the lid, it’s in the key drawer. Man was I happy, I learned 2 good lessons the last few days, keep at least one set of keys out of the car and and ask the wife before I go in to panic mode.
I really appreciate all my vette brothers coming to my assistance.
Old Feb 11, 2014 | 09:31 PM
  #36
Joe B.'s Avatar
Joe B.
Good job. How did your wife get in the car?
Old Feb 11, 2014 | 09:34 PM
  #37
Richard Ames's Avatar
Richard Ames
Leaving a key fob in the car is not responsible which you demonstrated for your reason and making it easier to steal. You should take you wife to a nice dinner for taking care of you also. Some insurance companies exclude theft coverage if you leave your keys in the car.
Moral is to remove all items including wallets, cell phones and keys/fobs when you exit the vehicle.
Glad you had a happy ending.
To Screwed or what?
Old Feb 11, 2014 | 09:57 PM
  #38
Boomer111's Avatar
Boomer111
Auto club will send locksmith out he will send vin to get code to cut new key. Just went through this and it took a total of 30 minutes from call to getting into car.
Old Feb 11, 2014 | 10:08 PM
  #39
c6miller's Avatar
c6miller
Originally Posted by PatriotZ
I believe that worst case senerio is have a locksmith come to your house and get/make a key for the rear hatch.....and go in that way....I think a new FOB is around 150.00 ish....and you certainly don't need it since you already have two.....Best case is your dealer may be able to make a hatch key with your VIN number....(probably the cheapest way out....unless you know a key person...
There's your answer!!
Old Feb 11, 2014 | 11:20 PM
  #40
SuperDave02's Avatar
SuperDave02
Wish I would of known the shake the car thing. I locked my keys in last week. But only being about a mile and half from home, I walked home broke a window to get in and got the extra FOB. Window only costs 40 bucks to fix.
