Interior Panel Removal
Old Feb 14, 2014 | 04:19 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Interior Panel Removal
I was wonder about the removal of a few different interior panels. I know how to remove the center console radio surround, the bezel around the gauge cluster and the door button bezels, but I am not sure about the plates that cover the door locks/memory controls, the window switches and mirrow controls. Also the steering wheel control covers. Are thes just a snap fit or is there more to it?
Old Feb 14, 2014 | 04:37 PM
tennblkc6's Avatar
tennblkc6
i'm interested in this too. are you going to attempt the carbon fiber vinyl wrap?
Old Feb 14, 2014 | 04:41 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Yes
Old Feb 14, 2014 | 05:00 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
Door switches pop off
Steering wheel pieces. You need to remove airbag there are holes in steering column use a small screwdriver and press in to release clip on either side to release air bag, once popped unscrew the covers
If you are going to unplug I would disconnect the battery
Old Feb 14, 2014 | 05:02 PM
wayback's Avatar
wayback
More to it. Door panel must be removed. Under door pull is a snap in cover, there are 2 bolts there. Door panel is held on by post/recp. And must be swung out then lifted up. Lock panel is held on by 2 inverted hex speed nuts. They break often when removed. Can use a small screw and washer to repair. Ask me how I know.
Search for Paul Talons website the redlion.com. great step by step instructions there.
Old Feb 14, 2014 | 05:10 PM
mcandrew67's Avatar
mcandrew67
Was thinking door release buttons as I redid those
Old Feb 14, 2014 | 05:17 PM
wayback's Avatar
wayback
Old Feb 14, 2014 | 05:22 PM
mcandrew67's Avatar
mcandrew67
When I changed out my door panel some of the white retainers broke too so if you do remove it you may want to get extras of this too
Old Feb 14, 2014 | 05:24 PM
tennblkc6's Avatar
tennblkc6
how do I remove the bezels that holds the hud and options buttons ?
Old Feb 14, 2014 | 06:09 PM
drich2905's Avatar
drich2905
a steady pull on that pod and it will come loose enough to get to the
clips.
Old Feb 14, 2014 | 10:14 PM
Dano523's Avatar
Dano523
Door panels removal write ups have been done on the speaker upgrade mods, and as for pulling the gauge cluster and it trim, look up the video on the 2005 steering wheel lock eliminator.
As for pulling the steering wheel and clock spring, look up Steering wheel lock replacement on the 2005.
Old Feb 15, 2014 | 04:15 PM
bucwheat's Avatar
bucwheat
How about the ashtray door?
Old Feb 15, 2014 | 05:24 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
ashtray door is part of the whole ashtray assembly. You have to remove the radio/console bezel to take out the ashtray assembly from the bezel rear.
Old Feb 16, 2014 | 10:50 PM
bucwheat's Avatar
bucwheat
No ,I got it out without pulling the console,pretty easy,but now I can't get the little spring on the side back in to raise the door on it's own.
Old Feb 22, 2014 | 01:27 AM
vara411's Avatar
vara411
I'm interested to hear how you pop out the plastic bezel around the gauge cluster. I have a squeak going on in there that's driving me crazy and the fix I read about requires that this piece be popped out a bit. Anyone?
EDIT: Okay so I answered my own question. Here's the link for other folks...
https://www.corvetteforum.com/c6-cor...ml?styleid=140
To Interior Panel Removal
