!@#$%^& Plug Wires
Old Feb 21, 2014 | 10:35 PM
NotVincent's Avatar
NotVincent
Default !@#$%^& Plug Wires
This is now thw second time in 6000 miles with my 427 that I have been afflicted with the traction control and engine lights coming on while the car sputters to a halt in a parking space. As expected, I found a few plug wires had fallen off. Is it worth getting a new set under warranty or are the aftermarket leads that much better? I am starting to regret replacing my German cars.
Old Feb 21, 2014 | 10:51 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
This is a car you got new and it's not engine-modified? I've heard/read of one wire loosening, but NOT a few loosening. Presume these are stock plug wires and plugs and that you check them once they put on the new ones.
Old Feb 21, 2014 | 11:03 PM
NotVincent's Avatar
NotVincent
New car, totally stock - except for the engine replacement at 5000 miles. The dealer re-used the original plug wires when the engine was replaced and said if I had any issues with them to bring it in and they would replace them. I just think a new set that actually stays in place is worth the price rather than my time and energy going to the dealer.
Old Feb 21, 2014 | 11:46 PM
Dano523's Avatar
Dano523
The factory wires are fine, and will last the same amount as the spark plugs (100K).
The problem is when you pull the wires for the first time that are factory installed (solvent installed that causes the boots to stick to the plugs and coil caps), you have to be careful or you can cook them on the first time removal.
Best guess is when they did the engine swap, they just yanked out the spark plug wires, and this is the problem at hand (new set of factory wires will solve the problem).
Old Feb 21, 2014 | 11:48 PM
POPN427's Avatar
POPN427
Old Feb 21, 2014 | 11:57 PM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
Could have fallen off because the mechanic did not get them fully seated. I've seen it happen.
Old Feb 22, 2014 | 12:09 AM
NotVincent's Avatar
NotVincent
No. My dealer's mechanic is top-notch. They fell off before when the car was new before the engine or anything else was touched. I may just let the dealer replace them with new ones but damn, is it really that hard to design a plug wire that doesn't fall off?
Old Feb 22, 2014 | 12:19 AM
Cyber Greg's Avatar
Cyber Greg
No it's not and the reality is you're having a very isolated experience. Just go get the new wires put on and be done with it.
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
New factory wires will be fine...the mechanic can be top notch but people he could have been in a hurry and if they were loose to begin with he had no chance of leaving them in tact.
Let the dealer put new wires on and you won't have another problem so long as they properly click them into place.
Old Feb 22, 2014 | 06:17 AM
Don-Vette's Avatar
Don-Vette
Plug wires don't just "fall off" if they are put on correctly. You need to hear and feel the click sound the terminal makes when it snaps over the connector of the spark plug. You don't just push the boot on as far as you can and think your making a good connection.
When I put the MSD wires on my GS,I spent plenty of time on each wire until I felt that plug wire snap over the connector. I also used a tiny dab of dielectric grease inside the plug boot.
Old Feb 22, 2014 | 09:15 AM
wayback's Avatar
wayback
When I replaced my wires and plugs they came pre greased and had heat boots. MSD wires also. No problems with either the factory or MSD wires.
Old Feb 22, 2014 | 09:28 AM
NotVincent's Avatar
NotVincent
Maybe someone should send these installation notes to GM because I had 3 wires fall off their coils before the engine compartment was ever touched by me or anyone else.
I will have my dealer replace them this week. Thanks.
Old Feb 22, 2014 | 10:15 AM
dennis50nj's Avatar
dennis50nj
I have had my same wires for 36000 miles 8 years, They have been R&R many times as needed for all the mods were done one at a time, different plug heat ranges different gaps and indexing different headers, I replaced with OEM GM, never had one fall off. The trick is to always do a light coating of the inner boot with a qtip and dielectric cream
Old Feb 22, 2014 | 02:53 PM
HOXXOH's Avatar
HOXXOH
115K on my '08 with original wires that have been on and off several times and have never "fallen off".
When the dealer stated if you have a problem he'd replace them, so just do it.
Old Feb 23, 2014 | 07:10 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hey NotVincent,
I would like to document the concerns you are having with your wires in our system. Will you please send us a PM with your info? I am pretty sure we have talked in the past, so I am sorry that you continue to have concerns!
If you go to the dealership prior to replying to us, please keep us all updated on your visit.
Have a great night,
Kelly J.
Chevrolet Customer Care
Old Feb 23, 2014 | 07:39 PM
erikszr1's Avatar
erikszr1
many times plug wires need to be burped of air that's trapped under the boot while installing them. this can be done with a simple hook/pick tool. be careful not to puncture the boots while doing this. GM tech here.... new wires can and will do the same thing. new wires is not the cure all, save yourself a trip to the dealer.
Old Feb 23, 2014 | 07:42 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
In my entire life I have never had a Plug Wire fall off, your mechanic must not be too bright. If it were me I would buy my own wires and install them myself. My time is worth more than going to the dealer, leaving the car and then going back because someone does not know how to put on a spark plug wire.
To !@#$%^& Plug Wires
Old Feb 23, 2014 | 08:28 PM
z06clif's Avatar
z06clif
I seen it 3 times this last summer. Plug wires not burped. Seems like the air inside gets hot and expansion happens. Crazy right ?
Clif
Old Feb 23, 2014 | 08:38 PM
NotVincent's Avatar
NotVincent
Gee, I guess that fine union help at Bowling Green must be even dimmer. Three of the wires they installed fell off the coils before anyone ever touched the engine compartment.
Old Feb 23, 2014 | 10:33 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Haven't thought of that in quite awhile. I recall "feeling" this a long time ago w. another car re slipping on plug wires.
Maybe not exactly trapping air, but I do recall the old distributor caps and how some of the boots would have problems going on until they were essentially "burped," altho that may not be what it was called at the time. Many also had that positive "click" to know it was seated properly and wouldn't shake loose.
