Advice please...
Old Feb 23, 2014 | 10:28 AM
blittle's Avatar
blittle
Default Advice please...
Hi guys…. I was one of the original C6 section founders back in 04 when some of us started ordering our 2005 Vettes…..left when I sold out in 07. BUTTT……am considering a return and am looking at a 12 GS with 4500 miles on the meter. Interested in knowing what one item you might suggest I look for or lookout for …… or "need to know" item? Thanks!
Old Feb 23, 2014 | 10:35 AM
DillingerRadio's Avatar
DillingerRadio
St. Jude Donor '14
Nothing I can think of off the top of my head: get a carfax, make sure everything's legitimate.
Outside of that, the usual small foibles you'd be looking at with any used car you'll want to inspect on the 'vette. I don't know of anything significant on the '12 GS though that you'd want to keep an eye out for.
Make sure you take it for a test drive and have it inspected by a mechanic you trust.
Old Feb 23, 2014 | 10:44 AM
Huskerman's Avatar
Huskerman
2021 C6 of the Year Finalist - Modified
Welcome back to Corvette world.....I don't think there is a lot to be concerned with on the GS line as far as glitches. The only thing I can think of is be aware that the exhaust systems were changed in 12 and 13 to include a pair of catalytic converters under the console. The heat they generate can be enough that some folks are bothered by it and some aren't.
Good luck in your search the Grand Sport is a great car......I love my 2010.....
Old Feb 23, 2014 | 11:38 AM
Don-Vette's Avatar
Don-Vette
Look at the tire wear,get alignment checked if needed. Enjoy!!!!
Old Feb 23, 2014 | 11:42 AM
wayback's Avatar
wayback
Don't forget to change to ceramic pads.
Old Feb 23, 2014 | 11:47 AM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
The early production '12's had a recall for a rear hing (deck lid) replacement....no big deal, was replaced free of charge. As a '12 GS owner with 35K on the clock, just flatten out the front & rear alignment to .05 degree camber max and .100 toe in Max. and have fun driving.
Old Feb 23, 2014 | 11:49 AM
hisvett's Avatar
hisvett
OEM Brake dust is the pits
Old Feb 23, 2014 | 02:11 PM
blittle's Avatar
blittle
I seem to have been picking up on the alignment issue as I have been lurking here…… thanks for the advice! …..also the brake dust. I don't remember the brake dust issue on my 05. I am assuming the alignment adjust will help with some of the tire wear i have also been reading about?
Old Feb 23, 2014 | 02:39 PM
blittle's Avatar
blittle
Ok…..appreciate all the info! Amazing…. I can remember when I knew "everything" about a C6 (05 version!) Anyway…. how about the "performance exhaust" feature…..is that standard on the GS or was that an option that may or may not be on the vehicle?
Old Feb 23, 2014 | 03:33 PM
1968swbbigblock's Avatar
1968swbbigblock
NPP performance exhaust is an option on the GS
Old Feb 23, 2014 | 07:07 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Automatically goes to straight pipes about 3500 rpm, or you can get a Mild to Wild switch and open it any time you want. I like the foot switch, some have a separate clicker, and the Exhaust Commander programs it through the DIC buttons. All are great!
F55 magnestic suspension is available on the 2011 (?) and later GS, you can have a relatively soft ride for cruising but stiff for twisties or track use.
Old Feb 23, 2014 | 07:18 PM
DillingerRadio
St. Jude Donor '14
Kind of.. Butterfly valves in the two inboard exhaust pipes open under certain conditions. 3500rpm, and certain gear variable speeds if I remember properly. You can get a mild-to-wild switch, or just pull the damn fuse (no check engine lights will come on, the fuse is inconsequential) to keep them open all the time.
The F55 suspension is.. Hit or miss. If you don't have it, don't worry about it. I've read more than a few comparison/reviews and people tend to lean towards the Z51 (GS in our case) suspension over the F55 due to a slightly loose feel to the suspension. I can't honestly comment though, as I don't have any experience with it. But I do know that F55 shocks are expensive as .... to replace.
You said a 12 GS but I forgot to ask, what interior code? 1/2/3/4LT? If it's 3 or above look for Bose speakers and the heads up display. If he says it's 3LT or 4LT and you don't have a HUD, he's lying. Then again, a carfax of the VIN will tell you all you need to know on that. Good luck again!
Old Feb 23, 2014 | 10:05 PM
blittle's Avatar
blittle
Good advice….! Thanks to all! I'm seeing a lot of used 2012 GS on the market DONT have the "selectable suspension" option.:toeta
Old Feb 23, 2014 | 10:23 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'd get an IVH ck at any GM dealer free to see what tsb's or warranty work has been done, if any. Might also show a block on partial warranty if detected.
Since tires are so expensive, I'd physically look at inner treads on all four.
Old Feb 23, 2014 | 11:45 PM
cobrachuck's Avatar
cobrachuck
Look for heated seats for the winter
Old Feb 24, 2014 | 07:27 AM
blittle's Avatar
blittle
Exactly!! …given this one, for sure!
Old Feb 24, 2014 | 09:37 AM
dvilin's Avatar
dvilin
To Advice please...
Old Feb 24, 2014 | 10:21 AM
Sosoomi's Avatar
Sosoomi
If you are the kinda guy that will put on a custom exhaust I'd look for a car without NPP exhaust..... Otherwise it seems like a good system..... Works well and sounds good! I put a "Man Switch" in the glove box so I can turn it on and off.... It's usually on around town and when the roads demand "spirited" driving and off during long highway episodes. The NPP exhaust does drone a bit at highway speeds... The wiring instructions can be found in the forum with a search.... I think I have it saved somewhere if you need it...
Old Feb 24, 2014 | 10:37 AM
Huskerman's Avatar
Huskerman
My early 2010 did not have the NPP exhaust and I don't even know if it was an option then. I put a Corsa Cat back Sport exhaust system on the car and the music it makes is melodious......plus a lot less moving parts....
Big time on the heated seats....I scoffed at those when I first bought the car from the original owner.....but now wouldn't give them up for anything......
Make sure the fuel gauge is working well and make sure you fill it and see that the gauge still works.......those fuel level sensors can get hinkey and there is no easy way to change them out......also use a Tier One fuel like Shell 91 octane in it.....
Also if you can buy any extended warranty on the car before the original warranty wears out.......I didn't and have kicked myself on several occasions.....
Old Feb 24, 2014 | 03:43 PM
blittle's Avatar
blittle
Still the case, huh? I remember this issue with my C5 and then the 05 C6.
