Will this jack work?
Feb 27, 2014 | 12:56 PM
I need a jack for my new C6. Will this jack work "OTC 1532 Racing Jack"? If not which one works best? Thanks Daniel.
Feb 27, 2014 | 01:00 PM
St. Jude Donor '11
Oldtimer
Sure it will work. Judging by nthe picture it appear to be a low profile jack. I have a few home built ramps I drive the front up on and then I roll my floor jack under it at the front cross member to raise the front end.
Feb 27, 2014 | 01:19 PM
Got any pics of your home built ramps?
Feb 27, 2014 | 01:24 PM
St. Jude Donor '15
"In honor of jpee"
look up "Vet" on here. he has the definitive thread on it.
Feb 27, 2014 | 01:26 PM
2015 C6 of the Year Finalist
It will work for the sides and rear but it's not long enough or low enough to slide under the front.
If you're going to spend hundreds on a jack that you don't need to haul around then there are better ones. If you need the light weight of aluminum for portability, then it's fine, but there are cheaper alternatives out there.
Feb 27, 2014 | 01:41 PM
Well which one would you recommend as a cheap alternative?
Feb 27, 2014 | 01:45 PM
Quote:
Originally Posted by
D.Guerra
Harbor Freight has a couple goods that are under $100.
The Harbor Freight "racing" jack with a coupon is $69, I think. I have one in the garage and in the trunk of my other cars, just in case....
Feb 27, 2014 | 01:54 PM
Thanks I'll go by tomorrow and check it out.
Feb 27, 2014 | 03:01 PM
timd38
I had an aluminum one of theirs that had an LED light in the saddle so you could see where you were lifting. Lightweight and not very expensive.
Now I have an Omega long reach jack + another jack from Harbor Freight.
Feb 27, 2014 | 03:09 PM
I just got a jack from harbor freight love it. A 1.5 ton
Feb 27, 2014 | 03:16 PM
I made ramps out of 2x12s so I can use the standard craftsman jack.
I cut the 2x12s into lengths of about 2' 4' and 6' then stacked them. Also have piece of plywood on bottom that sticks out about a foot. The wheels run up on it first to prevent the ramps from kicking out.
Feb 27, 2014 | 04:56 PM
Nice that is a cheap alternative. I'm gonna try those
Feb 27, 2014 | 05:05 PM
Pick up some jack stands, too, if you're going to get under there.
Feb 27, 2014 | 07:09 PM
I use two jacks... One on each side.
Feb 27, 2014 | 08:13 PM
I've got a couple of those. I'm installing the LM1 and then soon I hope I'll tackle the headers and the rest of the kit.
