programming greeting
Old Mar 1, 2014 | 09:25 AM
donwil's Avatar
donwil
Default programming greeting
How do you program a personal message where it says Corvette by Chevrolet" and the a persons name or a phrase.I have seen "cleared to taxi" or "the need for speed"; how is this done? Thx for the help
Old Mar 1, 2014 | 09:41 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
It is all explained in the owners manual. If you don't have one, they are available on line in a PDF format. If you have an automatic, have the car in park, press the Options button and scroll through the different options until you find the section on what you want..
Hope this helps.
Old Mar 1, 2014 | 09:56 AM
donwil's Avatar
donwil
BWF07- Thankyou sir; some thing tells me Ive got a lot of reading to do. I will probably need to read that manual acouple of times.
Old Mar 1, 2014 | 10:01 AM
FlyerVette's Avatar
FlyerVette
Yes, once you reach the proper spot then you also need to scroll through each letter and or number needed for form the phrase you want. Takes a few (maybe more than a few) minutes to complete.
Old Mar 1, 2014 | 10:35 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Read the Manual a few times.
There are a lot of "quirks" to be aware of and plenty of options to personalize some of the operations.
Save yourself from some potential angst.
Old Mar 1, 2014 | 10:49 PM
florida john's Avatar
florida john
I copied another forum member's message "WEAPONS ARE ARMED" .
Old Mar 2, 2014 | 12:05 AM
Vette_DD's Avatar
Vette_DD
Pages 5-61 and 5-62 in my owner's manual.
Personalize Name: This option
allows you to type in a name or
greeting that will appear on the DIC
display whenever the corresponding
RKE transmitter (1 or 2) is used or
one of the memory buttons (1 or 2)
located on the driver door is
pressed.
Press the OPTION button until
PERSONALIZE NAME appears on
the display, then press the RESET
button to scroll through the following
modes:
. YES
. NO (default)
If you choose YES, you can type in
a name that will appear on the DIC
display.
To program a name, use the
following procedure:
1. Enter the PERSONAL OPTIONS
menu and select the driver
number (1 or 2) that you would
like to program by following the
instructions listed previously
under “Entering the Personal
Options Menu”.
2. Press the OPTION button until
the PERSONALIZE NAME
option appears on the display.
3. Select YES under
PERSONALIZE NAME by
pressing the RESET button.
4. Press the OPTION button and a
cursor will display where you
can insert a letter.
5. Press the OPTION button again
until the letter you want is
displayed. To scroll through the
letters faster and without a
beeping noise, keep the
OPTIONS button depressed.
There are alpha/numeric
characters and a blank space
available.
6. Press the RESET button to
select the letter of your choice
and proceed on to the next
space to the right.
If you make a mistake and would
like to clear or replace a letter,
perform the following steps:
6.1. Press the RESET button to
reach the letter you would
like to change.
6.2. Press the OPTION button
to scroll through the letter
choices.
6.3. Press the RESET button to
select the letter and
space to the right.
7. Repeat Steps 5 and 6 until the
name or greeting you want is
complete. After the name or
greeting is complete, keep
pressing the RESET button until
the display turns blank and exits
out of this option. You can
program up to 20 characters.
If you choose NO, this option will
turn off.
If a customized name or greeting is
not programmed, the DIC display
will show Driver 1 or Driver 2 to
correspond with either the
number on the back of the RKE
transmitter (1 or 2) being used or to
the memory button (1 or 2) that is
pressed.
PERSONALIZE NAME is the last
option available to program in the
PERSONAL OPTIONS menu.
Pressing the OPTION button after
this setting will exit you from the
The last item you were in prior to
entering PERSONAL OPTIONS
will then display on the DIC.
Old Mar 2, 2014 | 08:24 AM
donwil's Avatar
donwil
JimTN- Thx for taking the time to post the info. Florida John-Thats pretty good! I have a brother that suggested "batteries to power, turbines to speed" (what Batman and Robin always said when they used the Batmobile)
Old Mar 2, 2014 | 05:17 PM
Woodstoc's Avatar
Woodstoc
My car programmed itself to say:
Paddle me Baby
Old Mar 2, 2014 | 05:20 PM
owc6's Avatar
owc6
Paddle me Baby
I'm assuming you have an A6.
lisa
Old Mar 2, 2014 | 05:35 PM
Woodstoc's Avatar
Woodstoc
lisa
I do, she loves to be paddled.
Old Mar 2, 2014 | 05:41 PM
owc6's Avatar
owc6
Old Mar 2, 2014 | 07:04 PM
z06clif's Avatar
z06clif
Ive got my 06 for 8 years now and I still read it. They also came with a DVD for the car and the nav
Clif
Old Jun 10, 2024 | 07:57 PM
afsZ06's Avatar
afsZ06
2nd Gear
Default 2011 C6 Clear Previous Personal Info
I have the instructions from this post and my manual.
BUT, nothing is mentioned regarding clearing (deleting)
the existing name(s).
This would help, Thanks.
Old Jun 10, 2024 | 09:02 PM
BuckeyeRay's Avatar
BuckeyeRay
AFAIK you just overwrite what's there. There might be a "factory reset" option, not sure. Get into the menu and play around.
Old Jun 11, 2024 | 03:07 AM
sirdano's Avatar
sirdano
mine says " welcome aboard Captain Engage"
Old Jun 11, 2024 | 05:02 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
Mine says: "you have to drive it home" and i also programmed my car play to say "remember dipshit, you have to drive it home" everytime it connects. Its a firm reminder lol
To programming greeting
