Fob programming question
So, you need to do the "long programming procedure" which erases all currently stored FOB ID's then starts over fresh with #1, then the 2nd one programmed will be #2, etc.
Here are tried and tested instructions:
http://forums.corvetteforum.com/c6-c...tructions.html
If you run into problems, that thread is huge, with lots of identified issues and tips and tricks. It's a lot of reading to find help but it's all there.
It doesn't matter what number is engraved on the back of the fob, it's how and when it was programmed for the car.The car had 2 fobs programmed for it when it left the factory. One was programmed as fob #1 and the other was programmed as fob #2. When you got the car with only 1 fob, the other fob was somewhere else, either lost, or kept by the previous owner, or stolen.
If the short programming procedure was used to simply add a new fob, it got programmed as the next unused fob #, probably #3. Fob nos. 3 & 4 have no memory capability.
If you want both fobs to have the memory capability, you'll need to do as Rick T says and reprogram those 2 fobs as #1 and #2. I would suggest that you might want to do that programming in a Chevy dealer's parking lot in case you have a problem with it, and many people do.
