Oil pan bolts
Oil pan bolts
I read a post recently that someone had taken their vette to the dealer to have the oil pan bolts retorqued (sp?) and it fixed the small leak he had. I would like to try this first myself if I can get underneath the car enough to get good access. How many of the bolts should I have reasonably good access to to re-tighten? Also, what is the correct torque? I will get a torque wrench before I start.
Front bolts have no clearance, practically resting on cradle. If you jackstand at side pucks to crawl under & than jack up the tire it'll compress suspension/spring & give you room for an open end wrench to slip in between cradle. No room for socket at front though. Side & rear bolts were easy to access. I didn't follow any pattern just did a little each & came around again. Forget the torque values. Didn't cure my oil leak, had to bring in for a gasket.
Received 2,077 Likes
St. Jude Donor '13
Dealer torqued mine and it seems to have stopped the oil seepage.
Unfortunately, no idea what technique or sequence he used.
The Service Manual has the torque values, but my manual is not with me right now.
From torque guide for 2007 C6
Oil Pan Closeout Cvr Bolt (Left & Right side) 80 lb in
Oil Pan Cover Bolts 106 lb in
Oil Pan Drain Plug 18 lb ft
Oil Pan M6 Bolts - pan rear seal 106 lb in
Oil Pan M8 Bolts - pan-block & pan-cover 18 lb ft
sequence, I don't know...
Received 2,062 Likes
Mine is at the dealership right now having the gasket replaced.
They are going to give the car a once over and make sure everything else is good. Mine had been leaking for a month or so but I had to wait to bring it to a dealership 3 hrs away. It was a small drip but I wanted to make sure a had a service dept with an awesome rep do it.
Lisa
Lisa
Lisa
Lisa
Wish I could help you.
Lisa
St. Jude Donor '13
I coulda swore that some other folks have had the alignment covered by the warranty when the oil pan gasket was replaced.
Who else has had the alignment covered or not covered?
Received 1,514 Likes
my alignment was covered - I remember they did it because it was discussed and they never tried to get me to pay for it - mine was done under the powertrain warranty and not the bumper-to-bumper
