Driver's settings
Old Mar 18, 2014 | 04:24 PM
biker1059's Avatar
biker1059
Default Driver's settings
Ok, had the vette about a month and there's one thing I think is not working right. When I get into the car with the #1 fob should the settings I put in like seat position and mirrors go to those positions without pushing the #1 button on the door? When I push the #1 on the door everything goes to the right position. Is this right or should it do it when I turn the ignition on.
Old Mar 18, 2014 | 04:33 PM
Vette_DD's Avatar
Vette_DD
Will do it automatically after you start the car. GM's lawyers don't want your seat moving while you're trying to start the car.
2006 owner's manual, page 2-73.
To recall a memory position, do one of the following:
• If you have an automatic transmission vehicle,
press and release the desired button 1 or 2 while
the vehicle is in PARK (P).
A single beep will sound and the memory position
will be recalled after a brief delay.
If the vehicle is not in PARK (P), three beeps will
sound and the memory position will not be recalled.
• If you have a manual transmission vehicle, press and
release the desired button 1 or 2. If the vehicle is on,
the parking brake needs to be set to recall the
memory position.
If the vehicle is on and the parking brake is not set,
three beeps will sound and the memory position will
not be recalled.
If your vehicle has the Auto Memory Recall feature and
it is turned on in the Driver Information Center (DIC),
the seat, mirrors, and telescopic steering column
position will automatically adjust to their programmed
positions when the engine is started. See “Auto Memory
Recall” under DIC Vehicle Personalization on page 3-68
for more information.
To stop recall movement of the memory feature at any
time, press one of the power seat controls, power mirror
control buttons, memory buttons, or the telescopic
steering column switch.
Old Mar 18, 2014 | 04:44 PM
biker1059's Avatar
biker1059
Thanks JimTN, I see where it says if you have a manual trans you have to push the 1 or 2 button.
Old Mar 18, 2014 | 06:26 PM
Vette_DD's Avatar
Vette_DD
Oops, yes, I forgot about that. I've only owned automatic tranny cars for the last 9.5 years.
To Driver's settings
