cd player
Old Mar 21, 2014 | 07:36 PM
jlbsam's Avatar
jlbsam
Default cd player
I have a question about the cd player in my 07 with nav. with a cd in, and start up the car, the cd player doesn't work. i have to open the screen, eject and close, and then sometimes it still doesn't play and other times it does. what the secret?
Old Mar 21, 2014 | 07:52 PM
saplumr's Avatar
saplumr
Did you burn the CD?
Old Mar 21, 2014 | 07:57 PM
jlbsam's Avatar
jlbsam
no, it's a Journey cd bought from amazon
Old Mar 21, 2014 | 08:00 PM
saplumr's Avatar
saplumr
Does it happen with all cd's or just that one.
Old Mar 21, 2014 | 08:55 PM
VET4LES's Avatar
VET4LES
In the nine years I've owned mine, I've had several issues like this and I found that disconnecting the battery has fixed it each time. It's happened maybe three times.
Old Mar 21, 2014 | 09:40 PM
jlbsam's Avatar
jlbsam
i will try that tomorrow. in my 99, disconnecting the battery solved a lot of problems, but that was a short term solution. the long term solution was A NEW BATTERY. i may need one
jlbsam's Avatar
jlbsam
all of them
Old Mar 21, 2014 | 10:26 PM
Vette_DD's Avatar
Vette_DD
Don't forget that after you reconnect the battery, you'll probably need to reset the window indexing for both windows.
http://forums.corvetteforum.com/c6-c...-indexing.html
Old Mar 22, 2014 | 12:36 AM
LedZepper's Avatar
LedZepper
Suggest you try a Led Zep cd ... Physical Graffiti.
Old Mar 22, 2014 | 08:00 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
BINGO!!!
Old Mar 22, 2014 | 10:23 AM
EVRose's Avatar
EVRose
A couple of shots of compressed air in the cd slot solved that same problem on mine.
Old Mar 22, 2014 | 11:35 AM
cclive's Avatar
cclive
The car is a very dusty environment and dust is the enemy of the laser lense that reads the CD. I need to do this with mine as it frequently loses lock on the CD and goes to the next song before finishing this one.
Old Mar 22, 2014 | 05:22 PM
jlbsam's Avatar
jlbsam
the shot of compressed air sounds like it might be the answer. i've owned the car for a month and it came from texas, a dusty environment. i'll give it a try. thanks for the tip
To cd player
