manual door release doesn't work right
So, the other day my battery died. (I had left the car in 5th instead of reverse.) I used my metal key to open the trunk and pull the manual door release, so I could open the hood and take out the battery. The driver's door popped open a bit, but was still latched, so I couldn't open it.
Fortunately, the top and windows were down, so I just reached in and pulled the hood release. But I'm wondering why the door didn't open properly, since I may have to use this release some day when the top and windows are up, or when I need to get inside the car.
Has anyone else had this problem? I tried it twice (shutting the door all the way again after the first try), and the same thing happened both times. Is my door release not adjusted properly? I tried pulling on the release (in the trunk) several times, and pulling harder. No luck.
Received 2,061 Likes
Thanks!
St. Jude Donor '10-'11-'12-'13-'14
I imagine that since the window doesn't index down (because the battery is dead), the weatherstrip holds the door tight against the frame. Not much you can do except have a helper open the door or have very long arms.
Does the same apply to the manual door releases located on the floor? I didn't think to try those when my battery was dead.
Neither manual release will lower the window.
You just have to exert a little extra effort to get the door open.
There's also a pull for the fuel filler door and if you have a convertible, there's a t-shaped, glow-in-the-dark handle near the latch that you can use next time you're locked in the trunk.
Received 2,051 Likes
St. Jude Donor '13
IIRC, the manual release will try to index the windows, and so they will index if the battery is still good enough. But if the battery is dead, then no indexing.
I tried the release again, and the same problem occurred. The door popped loose, but couldn't be opened. I then tried the method suggested by HOXXOH, which worked (and it was an easy reach). Strangely, once I had opened the door in this way, the manual release started working properly. I closed the door, pressed lock on my fob, pulled the release, and the door opened fully. I repeated this test four times, and it worked every time. So I have no idea why the release works in some situations but not others.
Anyway, I now know how to open the door in an emergency, so I'm grateful to all who responded.
Happy motoring!
