C6 issues ?
Old Mar 30, 2014 | 06:54 PM
C5at16's Avatar
C5at16
Default C6 issues ?
So my brother is looking to get a c6 base. I have a c5 so I am familiar with the c5's issues but I was wondering if the c6 has any of the same as the c5 did? The c6 my brother is interested in has a STS twin turbo kit on it as well.
Old Mar 30, 2014 | 07:04 PM
owc6's Avatar
owc6
Well, that was sufficiently vague! :P
Any things in particular? I know the '05 has basically the same steering wheel as the C5.
lisa
Old Mar 30, 2014 | 07:33 PM
Mad*Max's Avatar
Mad*Max
I never had a C5 - what issues did it have?
Old Mar 30, 2014 | 07:59 PM
Red08's Avatar
Red08
Every generation of Corvette had some issues. Is there something in particular that you are concerned about?
Old Mar 30, 2014 | 08:06 PM
R&L's C6's Avatar
R&L's C6
I would be more concerned about buying a car that was modded with twin turbos. That just screams it could have had the $h!t beat out of it. JMO
Old Mar 30, 2014 | 08:07 PM
C5at16's Avatar
C5at16
Issues such as the steering column lock, ground wires getting moisture in them, leaks, cheap interior stuff along those lines. Any common issues with the c6's though ?
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Originally Posted by R&L's C6
I would be more concerned about buying a car that was modded with twin turbos. That just screams it could have had the $h!t beat out or it. JMO
Old Mar 31, 2014 | 07:56 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
(This could add up fast.)
Personally the only way I would consider that car is with $15K off comparable prices assuming the engine will have to be replaced but I'll risk the cost of the possible transmission and rear end problems. Maybe the car was babied after all the cost of beefing it up but why risk it?
As far as common C6 issues, 2005 had a weak rear and DBS. After that they are all pretty much very reliable daily drivers.
Old Mar 31, 2014 | 08:20 AM
EBvette02's Avatar
EBvette02
A lot of people have harmonic balancer issues. I had it on my 06 at about 52k miles. I also had the headlights turn off because of a broken wire in the fuse box. Fixed it in less than 2 hours. But other than that. Its been a great car.
Old Mar 31, 2014 | 04:36 PM
C5at16's Avatar
C5at16
Thank you guys for the replies!
Old Mar 31, 2014 | 04:51 PM
Tonylmiller's Avatar
Tonylmiller
Many have a rocking seat issue, similar to the C5s but different. And have him check the oil pan for leaks. That is $1000 to fix.
I haven't heard many people who have problems with the gears in the hidden headlights on their C6s. That's one good thing.
Old Mar 31, 2014 | 06:19 PM
jackhall99's Avatar
jackhall99
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Read the "Known Issues" section.
http://forums.corvetteforum.com/c6-c...questions.html
To C6 issues ?
