2012 g6
Old Apr 4, 2014 | 11:06 AM
Caspar's Avatar
Caspar
2nd Gear
Default 2012 g6
Which battery post is grounded on a 2012 c6?
Old Apr 4, 2014 | 11:13 AM
Caspar's Avatar
Caspar
2nd Gear
Default 2012 c6
I have a 2012 Corvette C6, and I need to charge the battery. Which post is grounded the ?
Old Apr 4, 2014 | 11:14 AM
icntdrv55's Avatar
icntdrv55
All modern 12V systems are coded red for hot (+) and black for ground (-). Ground goes to the block/frame; hot goes to the starter solenoid terminal. Not sure if that's the question you're asking, but when you're disconnecting, always remove the ground first, then the hot. That way, if you accidentally make contact with the frame/engine, you won't get an arc.
To 2012 g6
