e brake boot
Old Apr 5, 2014 | 02:04 PM
pk5's Avatar
pk5
Default e brake boot
I bought an e brake boot from corvette mods and i can't figure out how to install the damn thing. There is no way the leather is gonna fit over the handle and if I take the handle off there's no way the leather is going down far enough to be able to screw the handle back on. Any help?
Old Apr 5, 2014 | 05:12 PM
BOBSZ857's Avatar
BOBSZ857
Try peeling down down the boot on the console side enough to expose the set screw. Remove screw (phillips #2), and then apply upward pressure on the handle. This will take the handle off. Once this is done, stick you fingers into the boot material closest to the console and apply gentle pressure pulling upwards until the 2 clips release. You may have to do the same on the outer side as well. Once removed, slide new boot over the lever and do the reverse. When you have the clips all snapped back, replace the handle and re- install the set screw. You may have to kind of pull the boot down a little to get the screw back in. Good Luck, I hope this helps.
Old Apr 5, 2014 | 06:33 PM
Kvothe's Avatar
Kvothe
Once you have it off this video helped me:
Old Apr 5, 2014 | 06:40 PM
not08crmanymore's Avatar
not08crmanymore
ONE ISSUE I'VE HAD WITH MULTIPLE boots I've tried to install over the years is the e brake won't fully release with that thick leather boot on it. So the brake light never goes out because it's not fully disengaged.. For this reason I never put anything like a dsvettes boot on again.To bad too, quality stuff.
To e brake boot
