C6 Documentation - Build Sheet
Old Apr 8, 2014 | 06:15 PM
71stngr's Avatar
71stngr
2nd Gear
Default C6 Documentation - Build Sheet
Does anyone know where you can get reprints of the original documentation on C6 Corvettes? Like the build sheet, window sticker, etc....? I have a friend that purchased an 05' C6 and he received all of the original documents with it, and thought you could order reprints from somewhere, but didn't know where. Might be nice to get this info.
Old Apr 8, 2014 | 06:20 PM
Rajohnson's Avatar
Rajohnson
I believe that you can request that info from the NCM
Old Apr 8, 2014 | 06:34 PM
leo lossett's Avatar
leo lossett
yes you can get that info from the NCM i got my build sheet and window sticker both came laminated and look great
Old Apr 8, 2014 | 07:27 PM
lordofwar's Avatar
lordofwar
got he build sheet from the national corvette museum.my window sticker.you can get a window sticker from them also.
Old Apr 9, 2014 | 10:00 AM
Knoxrower's Avatar
Knoxrower
I've thought of getting it myself:
https://store.corvettemuseum.com/ser...buildsheet.asp
Old Apr 9, 2014 | 03:38 PM
spdkilz911's Avatar
spdkilz911
I did this also
Old Apr 10, 2014 | 07:58 AM
bonnell's Avatar
bonnell
When I bought mine a couple of weeks ago it came with these. I really like them.
I wanted to buy these for my previous vette but I never did. I'll have these framed together.
Old Apr 10, 2014 | 08:03 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
The build sheet from the NCM isn't just a reproduction. It will most likely be an original sheet that went down the line on the car with all the tape and smudge marks and...
The window sheet they have will obviously be a reproduction unless you got it when you took delivery at the NCM as I did.
Old Apr 10, 2014 | 01:54 PM
surburban99's Avatar
surburban99
Same here, ordered the build sheet and window sticker laminated.
Old Apr 10, 2014 | 02:08 PM
71stngr's Avatar
71stngr
2nd Gear
Default build sheets for my 05' C6 vette
Thanks for all of your responses...... I will contact the NCM and purchase whatever I can for the car. I also have a 71, which I will also try and get the paperwork for, but may not be available. Thanks to all - you are all appreciated.
Old Aug 23, 2021 | 07:01 PM
ROBOPTI's Avatar
ROBOPTI
Just an FYI for anyone ... to see what you get when you do go to NCM ... I ordered my window & build sheet / laminated copy & paper copy from the museum a month or so ago ....
EAXCTLY as ordered
Old Aug 23, 2021 | 07:30 PM
Iceaxe's Avatar
Iceaxe
For your 71 if the build sheet is not on top of the gas tank or tucked somewhere behind the dash you are **** out of luck as GM did not keep Corvette records until the move to Bowling Green. The one exception is if the car was delivered in Canada.
Old Aug 24, 2021 | 06:59 PM
z06clif's Avatar
z06clif
I got paper , laminated , and wood. It was cut by laser from Great Lakes Trophy
Clif
To C6 Documentation - Build Sheet
