When to replace the TPMS
Old Apr 8, 2014 | 08:08 PM
geewez's Avatar
geewez
Default When to replace the TPMS
My C6 is now seven years old. How does one know when it's time to replace the TPMS sensors? I remember reading that the sensor battery is only good for about 6-7 years. When the battery goes dead does the DIC display a "SERVICE TIRES" error message?
Old Apr 8, 2014 | 08:20 PM
not08crmanymore's Avatar
not08crmanymore
If it ain't broke, don't fix it.Wait until you see some kind of message.
Old Apr 8, 2014 | 08:23 PM
EVRose's Avatar
EVRose
Mine were about 6 years old when I replaced them. I was getting XX on the DIC for the RR tire on and off. I got all of them replaced at the same time.
I agree with not08. Dont worry about it until you get weirdness on the DIC.
Old Apr 8, 2014 | 09:04 PM
johnodrake's Avatar
johnodrake
Moderator
They are supposed to last 10 years. I will Probably put new ones in when I change tires again.
Old Apr 8, 2014 | 09:09 PM
puzzleboy's Avatar
puzzleboy
On the C5, they're quite easy to change the batteries if you're at all mechanical. Anybody know if the 6 is similar?
Old Apr 8, 2014 | 09:33 PM
johnodrake's Avatar
johnodrake
Moderator
Easy to change, but the tire has to be removed (or partially so) to do it.
Old Apr 8, 2014 | 09:35 PM
EVRose's Avatar
EVRose
The batteries are not replaceable on C6 sensors.
Old Apr 8, 2014 | 09:37 PM
saplumr's Avatar
saplumr
I think it's probably easier to pull a tigers tooth than replace a TPM battery.
To When to replace the TPMS
