I have a 12 GS. After some research, Kooks 1 3/4 headers and catted X pipe seem the right ones for me since no FI planned. The I came across a post saying long tube headers need a tune otherwise running the risk of burning up the cylinder and getting half of the performance gain. I have replaced headers in my *** and Euro sports cars not doing a tune and they were running fine. Is Corvette different? For someone who have installed the Kooks headers, please advise.
I would like to know the answer also. I have always heard that a tune is need, or there is a good chance that you will start to get a lot of different codes. I also heard that you get the full benefit of the installation with a tune. So lets see what we hear back on this.
I bought an '07 a few years ago and it had American long tubes and high flow cats so I just assumed it was tuned.
After header installation of any brand, a dyno tune is highly recommended. I know guys who have passed on a tune post header install and driven for years without any serious issues. I know other's who used a canned tune after headers install without issues.
You are leaving some hp on the table by not tuning for the change in exhaust efficiency plus piece of mind knowing that the A/F is at an optimal range.
As much as headers cost for a c6, what's another 400 bux or so for a proper dyno tune to maximize the gain? You will have to tune out the o2 sensors if emissions testing is done in your area since you will get a check engine light and error code for the o2's. I'm catted with my long tubes and had to tune out the rear o2 sensors.
Agreed. Get a tune. You can change much more than just a "tune", like lower thermostat/fan settings, skip shift, top speed limiter, etc. You will have a different power curve after the tune also.
Tuning cost is not the issue here, but in my neck of the woods, there are no tuners/shops that can do the tune for US cars . Before I go through the efforts to ship headers over, I want to make sure that no tune is needed. Thanks.
You're not going to cause any damage by not doing a tune but as noted above, you're missing out on a lot of the benefit of the better breathing by not doing so. I'm running AR headers with their hi-flow cats & Corsa Sports mufflers. Tune was done by Doug Ring at ECS in NJ & the difference is very pronounced. Matter-of-fact, a good tune even without any engine mods will provide a noticeable improvement in performance.
There are vendors on this forum that offer remote tuning via Hp tuners(ECS is one) and email. You tell them what mods you have, they send you a base tune for the mods. Then you do some datalogging with hp tuners and a laptop, send the logs via email and they will adjust the tune based on the log, then send updated tune back to you. Quite simple and a great way to go when there are no tuners in the area.
You can also do this with a diablo intune and remote tuning via email and datalogging. No laptop necessary with this scenario. Mike from diablosport is also a CF vendor on here and can help if going handheld route.
In either case, if you have an A6 trans, the tune is DEFINITELY worth the price alone!
Thanks. I will research the remote tuning. I have a M6, BTW.
