they're both ridiculous for any trickle charger. I'd probably comply with the second just because it's easy, but I don't believe it will really make a difference.
I've been using $5 harbor freight trickle chargers on everything I own for a decade with issue, I don't know why people treat them as some mythological advanced piece of technology.
From: Metro Atlanta (by way of L.A.) Ga (Army Strong Retired)
I have been using a Battery Tender for years now with multiple applications in a garage - one stays on my ZR1 at all times unless I am driving it - always use a bolt on the block or chassis for the ground. On my other vehicles/boat/motocycle I do the same thing and never put both connections on the battery itself.
Both are safety measures composed by a legal department. A closed or non ventilated area usually means the passenger compartment. If a battery is located in the passenger compartment or trunk (Like my Benz) it needs to be in a sealed container that vents to the outside. A trickle charger hooked to the terminals would mean the top of the sealed case is open and the battery may off-gas during charging, filling the passenger compartment.
The legal people are also afraid of hooking the negative clamp to the battery post because IF any gas is present a spark could cause an explosion.
You'll be fine if the battery is under the hood. Attaching the negative clamp to the frame or block always seemed like a good idea to me if possible.
Reason: My spelling skills (or lack thereof)
