Question for those with non-drilled, non-slotted rotors...
Received 1,029 Likes
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
If you have the plain rotors on your C6, are the hubs gray, black or something else?
Just wonderin'.
Just wonderin'.
Hmm....
Did you buy the car with them like that, or are those replacements? I ask because I recently had my rotors replaced by my local Chevy dealer and they put black hubs in the front and grays on the rear just as you described. The service guy assured me that they were AC Delco genuine OEM equipment. I'd been using some after-market rotors and wanted to go back to original equipment.
Is it just me, or does anyone else think that the color of the hub of the rotors should match front and rear seeing how visible they are to even a casual observer?
Received 2,062 Likes
I drilled base rotors to match the same pattern as the larger J55 rotors and then zinc plated them. I assume you haven't driven the car much since they were installed, so they're still clean enough to plate without needing any extra prep. Not only will they both match, but you won't see future rust either.
Hmm....
Until they rust, they are the color of cast iron, which is grey, because that is what they are made of. I painted mine gloss black and it has held up very well. You'll never see a drilled rotor on a real race car...just for show on the street.
A very annoying mixture of gray and rust....my biggest flaw on the outside of my car....
even my little work ride 2011 Sorento and my wifes 2012 Sienna van both are perfect...no rust.....
Weight, especially rotating, is of significant importance for drag racers.
As long as we can slow down enough to make the last turn at the end, the brakes are sufficient.
The holes account for about 1.25# total on stock rotors and that's in addition to the 15# difference between the J55 and JL9 base rotors. I also saved 7 oz. by using open end lugnuts. Removing my door handles and chicklets was more for aero than weight.
Interesting! And I guess that does mean that there is a different standard for what is considered to be 'enough braking'...that last turn being the key...LOL
Most dirt latemodels also run drilled rotors.
Retired & lovin' it!
OK, since it is going to be picked apart, I'll revise my post to say real race cars like LeMans, IndyCars, etc. I don't want my C6 to imitate a drag racer or a dirt track car. I'll leave that for the drag racers and dirt track guys.
