wheel question
Old Apr 27, 2014 | 10:58 PM
NARIMAN's Avatar
NARIMAN
Default wheel question
if I get 18 inch rear wheels would it be ok, or I hear some problems running 18's on the back?
Old Apr 27, 2014 | 11:28 PM
smellya's Avatar
smellya
nope just make sure the front tires are smaller then the rears. I run 18x11 and 18x13 with 295/335 combo...
Old Apr 27, 2014 | 11:52 PM
NARIMAN's Avatar
NARIMAN
thanks
would 335 fit 12 inch wide wheels?
Old Apr 28, 2014 | 12:37 AM
NARIMAN's Avatar
NARIMAN
so this is not good?
I am looking in Hoosier a6
P255/35ZR18
P335/30ZR18
Old Apr 28, 2014 | 10:17 AM
haljensen's Avatar
haljensen
You need to stay VERY close to the original size difference between Front and Rear.
Size difference means diameter and it will vary with wheel size/tire aspect ratio and tire width.
It's possible to have nearly equal tire diameters in 16" to 22" wheels.
http://www.tacomaworld.com/forum/tirecalc.php
Old Apr 28, 2014 | 04:09 PM
dbratten's Avatar
dbratten
P255/35ZR18
P335/30ZR18
Running that combination will result in massive understeer (push). A ratio that works is the 315x30x18 F and the 345x30x18 R. F is on a 11"and R is on a 12" wheel.
--Dan
Old Apr 28, 2014 | 05:17 PM
smellya's Avatar
smellya
--Dan
Old Apr 29, 2014 | 12:29 AM
NARIMAN's Avatar
NARIMAN
thanks
so what exactly is bad about and what would happened with the car?
also I guess I better get 19 inch stock z 06 wheels?
To wheel question
