Dual Climate Control/AC problem
Old Apr 28, 2014 | 10:17 PM
crAzy's Avatar
crAzy
Default Dual Climate Control/AC problem
Ok about a year ago I got the whole AC assembly and condenser replaced under warranty. Recently it has been acting up to where when I start the car and put on AC it just blows outside air while it is showing 60* on climate control. That isn't right. So I go ahead turn it off and back on. Same thing. Long story short it is getting worse and worse and will eventually start blowing cold air. The past 3 times I have gotten the AC to blow cold the AC air honestly smells like fog machine smoke. It is very weird. I changed out the cabin air filter back in Jan or so of 2013. My car is a 2006 Z06 with 39K miles on it. Purchased it at 20K. Is it possible my climate control is going bad or something else? Everything is still under warranty. I just want to see what is wrong with it before I call them up and make a claim.
Old Apr 28, 2014 | 10:45 PM
RicK T's Avatar
RicK T
Does the air come out of the ducts you expect it to and can you control where it comes out, ie: dash vents vs. floor vents vs defroster? If not, you might have the dreaded actuator failure(s). If you do have control then it's probably the head unit.
Old Apr 29, 2014 | 12:16 AM
Rocketmanwpb's Avatar
Rocketmanwpb
If it is still under warranty get it in before the warranty is out. Best to be diagnosed by a tech. Hard to diagnose on the Forum.
Old Apr 29, 2014 | 09:20 AM
crAzy's Avatar
crAzy
I can control where it comes out. Yea I was prob going to do that. Just don't know if I want to take to dealership or performance shop. Also the buttons are wearing pretty bad so replacing the unit would be great.
To Dual Climate Control/AC problem
