Steering tolerences after alignment?
Old May 3, 2014 | 02:09 AM
dbratten's Avatar
dbratten
Originally Posted by cclive
And you have positive toe on one side and negative toe on the other...this is simply not acceptable. When I had mine done, there was .01 diff from one side to the other.
Having positive toe on one side and negative on the other (which looks like this \\ or //) only means that the steering wheel isn't straight. On the rear the same condition is thrust angle.
--Dan
Old May 3, 2014 | 12:45 PM
cclive's Avatar
cclive
--Dan
100%. The reason I mentioned it was because the straightness of the wheel was one of his compllaints. If the car is drifting slightly to the left then it can't be blamed on the crown of the road since that causes drift to the right.
