"Chriping" fixed!
Old May 2, 2014 | 10:45 AM
blittle's Avatar
blittle
Default "Chriping" fixed!
My chirping -squeak- squeak noise …..figured it out! Its a belt issue….soon as I put some silicone on the belt and let that run around a bit …..gone!! Thanks to various folks here who gave tips on diagnosing!
Old May 2, 2014 | 11:05 AM
EVRose's Avatar
EVRose
Post back here when it starts chirping again in a week.
Old May 2, 2014 | 11:21 AM
Wayne88's Avatar
Wayne88
It should not be chirping in the first place.
Old May 2, 2014 | 11:25 AM
Bat66's Avatar
Bat66
I had the same problem, took it in Tuesday and they changed the belts and tensioner, no more chirping.
Old May 2, 2014 | 11:33 AM
blittle's Avatar
blittle
Exactly! But at least I am now fairly convinced I'm not dealing with a harmonic balancer issue!
Old May 2, 2014 | 11:38 AM
Cherokee Nation's Avatar
Cherokee Nation
Simple fix.Put a Goodyear Gatorback belt on it.Amazon part # 4060798....
Old May 2, 2014 | 11:49 AM
EVRose's Avatar
EVRose
Well, the reason I said that is because usually when a dealer looks at the squeak issue they replace the belt and send you on your way. It starts again in a week or so and they put a new tentioner on it. Not long after that they finally realize the balancer is no good and replace that as a final fix. Not saying that's your situation but I've read of this scenario many times. I hope yours is a permanent fix. Fingers crossed.
Old May 2, 2014 | 11:51 AM
Walt White Coupe's Avatar
Walt White Coupe
If the chirping is caused by a wobbling balancer, changing/lubricating the belt will only temporarily mask the problem for 50 to 100 miles. The jury is still out.
Old May 2, 2014 | 12:59 PM
cclive's Avatar
cclive
Looking at the balancer while the engine is running is simple to do. There shouldn't be any uncertainty as to whether the chirping is caused by a balancer wobble issue. Some silicone is unlikely to fix the issue long term though, no matter what is causing it.
Old May 2, 2014 | 02:01 PM
blittle's Avatar
blittle
Ahhhh…ok, I thought if it was the balancer, the squeak is caused by the balancer itself and changing the belt or treating it with silicone or whatever, would do NOTHING?
Old May 2, 2014 | 02:20 PM
Walt White Coupe
A wobbling balancer does not chirp. It's the combination of the balancer wobbling and the belt running across it. Obviously changing the belt or lubricating it does do something to change the dynamic but that something is short lived.
Old May 2, 2014 | 03:06 PM
EBvette02's Avatar
EBvette02
Have you looked to see if your HB was doing the wobble?
Old May 2, 2014 | 04:52 PM
TerryL's Avatar
TerryL
St. Jude Donor '17
A simple bar of soap does wonders for a chirping belt IF you can manage to apply it w/o getting your hand caught somewhere. Its a temporary fix though but really works...temporarily.
Old May 2, 2014 | 05:19 PM
Cherokee Nation
That is what i used for many years on my hoopies...WORKS..
Old May 3, 2014 | 02:55 AM
erikszr1's Avatar
erikszr1
bad lifters make the same noise, for your sake I hope your good. many people have been fooled.
Old May 3, 2014 | 07:01 AM
Mrc100's Avatar
Mrc100
I was with your thought process. But it sound like from other comments the chirping could be caused by the belt's lateral movement over a pulley that is not running true. ? Keep us posted this will be interesting. Hope it' just a belt issue.
Old May 3, 2014 | 07:07 AM
Mrc100's Avatar
Mrc100
Why would he sound go away after spraying silicone on the belt if it was a lifter issue? I doubt it's a lifter issue in this case
To "Chriping" fixed!
Old May 3, 2014 | 07:27 AM
MARSC6's Avatar
MARSC6
Have you looked at the balancer with the engine running? All that silicone does is cover up a symptom. Whatever caused the chirping is still there.
Old May 3, 2014 | 08:20 AM
schmegeggie's Avatar
schmegeggie
Had the same issue until last weekend; 1 hour and 15 minute drive to Solloway's in Smyrna, $20, New balancer, belts and an oil change, $695. No Chirping sound.....priceless!
Old May 3, 2014 | 08:40 AM
jedblanks's Avatar
jedblanks
The chirping is because the worn/failing tensioner leans towards the front of the car and causes the belt to ride out of alignment. I new belt or spraying something on the belt to "soften it" will temporarily stop the chirping, but as the side of the belt rides on the leaning tensioner, it will cause more chirping, and eventually the pressure will cause the bearings in the tensioner pulley to fail as well.
Change your tensioner folks and save some $$$.
Source:
Been through this problem.
Step 1 new belts. (temp solve) $20 - $40
Step 2 new pulleys (no help) $100
Step 3 new gatorback belts (temp solve) $30
Step 4 new harmonic balancer (no help) ($2200 with cam swap)
Step 5 new tensioner. (Perm solve) $70
