Replacement tires.
Old May 8, 2014 | 02:31 PM
Tom E's Avatar
Tom E
Default Replacement tires.
Can anyone direct to a thread that discusses replacement tires for the originals on a 2011 Gran Sport? I don't want to repeat what probably been discussed a hundred times. Thank you.
Old May 8, 2014 | 02:56 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Try the search, although it is not always the easiest to us as far as results. Sometimes I find Google does a better job at locating issues on the forum. One thing, is your choice on brands of tires for the GS will be a lot more limited then the base model.
Old May 8, 2014 | 03:02 PM
richsteele's Avatar
richsteele
Here's a few to start with. Just a suggestion - you should probably decide if you are going to stay with Run-Flats or not first. That will narrow down your decision some.
http://forums.corvetteforum.com/c6-c...s-and-z06.html
http://forums.corvetteforum.com/c6-c...pe-2011-a.html
http://forums.corvetteforum.com/c6-c...-for-a-gs.html
http://forums.corvetteforum.com/c6-c...or-the-gs.html
http://forums.corvetteforum.com/c6-c...-their-gs.html
Old May 8, 2014 | 04:54 PM
kenownr's Avatar
kenownr
I'm not far from you and sent you a PM where I got a good deal on MPSS for my 12 GS.
To Replacement tires.
