Replacement Window Sticker can it be ordered?
Old May 16, 2014 | 12:36 PM
gmarcucio's Avatar
gmarcucio
Default Replacement Window Sticker can it be ordered?
Does anyone know if you can order a replacement window sticker for your GM vehicle and what the procedure is?
Old May 16, 2014 | 12:40 PM
Richard Ames's Avatar
Richard Ames
https://store.corvettemuseum.com/ser...buildsheet.asp
You can order through the National Corvette Musum
Old May 16, 2014 | 12:50 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
You stated GM vehicle, I am assuming you are referring to your Corvette. You can order them as already mention through the NCM. However, you will have to buy both teh window sticker and the build sheet.
Old May 16, 2014 | 02:46 PM
gmarcucio's Avatar
gmarcucio
No, I was actually asking for my other car Chevrolet Spark EV. I just thought someone would know if there was a generic GM site to order the replacement.
Old May 17, 2014 | 01:16 PM
Pa G 66's Avatar
Pa G 66
Unfortunately, the National Corvette Museum only supplies window stickers and build sheets from 81 on. Does anyone know how to acquire them for a 66? Thanks!
Old May 17, 2014 | 01:28 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
If you '66 is original. the build sheet should be on the top of the fuel tank. As far as the window sticker, I understand that all the records from the ols St Louis plant were lost in a fire. With pout those I am not sure how anyone could make up a valid window sticker.
Old May 18, 2014 | 12:02 AM
Pa G 66's Avatar
Pa G 66
Thanks! Not sure if the fuel tank is original but I'll check to see if the build sheet is there.
Old May 18, 2014 | 11:32 AM
frogwo's Avatar
frogwo
Build sheet on top of gas tank started in 1967 model year.
Old May 18, 2014 | 10:33 PM
Pa G 66's Avatar
Pa G 66
Well, in that case, looks like I am SOL!
Old Jul 26, 2014 | 12:05 AM
BigMac2395's Avatar
BigMac2395
Default Window sticker
Build sheets only available from corvette museum now. Hopefully that will change in the future.
Old Jul 26, 2014 | 10:17 AM
jimmie jam's Avatar
jimmie jam
Check NCRS, Hemmings and Google. I know that you can get one.
To Replacement Window Sticker can it be ordered?
