Michigan mornings are cool these days.
I start in the morning at 30 psi. In the afternoon tire pressure is at 34 psi.
Is that OK or should I adjust down to 29 psi or so.
I try to shoot for around 37 hot (around town) for optimal traction. This works out to around 34 cold, and somewhere around 42 on the track running hard. This was with my stock tires; haven't had a chance to mess with pressures much on the new PSS I just got.
I saw perfectly even wear on the first set running these pressures.
Seems to be on the higher pressure end for what I have read and my own experience.
I would think that the center of the tires would have worn early at 34 cold.
You probably did save a few coins in fuel cost though.
