Detailing help requested
Old May 20, 2014 | 10:55 PM
diitto's Avatar
diitto
Default Detailing help requested
Hi, This past weekend, for the first time on my 2 year old 2012 GS, I put a little bit of Adam's VRT Tire and Trim Dressing on the trim pieces at the top of both doors.
And over just a portion of the trim piece (not all of it but just maybe 1/3 of it) I now see what you see in the attached picture. Clearly I did this and the piece didn't look that bad before I started. Likely I just didn't wipe it off or in very well... But before I make a bigger mess I wanted to ask what folks suggest (or is Adam's Super VRT ok??) for these plastic trim pieces??? The car isn't out in the sun a lot. It's usually in the garage and covered but I had noticed a little whitish color on these parts, thus the reason I tried the Adam's for the first time on these parts just the other day. But something didn't work.
Suggestions??? see picture. Look at the whtishi blobs or spots on the trim piece. thanks bob
Old May 20, 2014 | 11:51 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
I use Turtle Wax plastic trim restorer. Works great and lasts a long time.
Old May 21, 2014 | 03:21 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
I use Aerospace 303 on all the plastic surfaces of the car, including the coated seats.
Cleans and provides UV protection and with light buffing, it doesn't leave the surface too shiny.
Old May 21, 2014 | 03:29 AM
jnguyenn16's Avatar
jnguyenn16
I have used meguiars back to black and it works very well imo
Old May 21, 2014 | 05:51 AM
Don-Vette's Avatar
Don-Vette
Mothers "Back to Black" at your local auto store. Use it on all black plastic trim and rubber moldings.
Old May 21, 2014 | 06:49 AM
dshamrick's Avatar
dshamrick
I use Adams all the time and have never had a problem. My questions is have you waxed the car before and did maybe some wax get on those pieces? If so, you will need to clean them first with something that will remove the wax and then apply again.
I have found that Super VRT is not really a cleaner but more of a protector.
If you put in on before you polish or wax, it will keep those products from getting onto those pieces.
Old May 21, 2014 | 07:55 AM
doubleD's Avatar
doubleD
Aerospace 303 works better than anything I have ever used.
Old May 21, 2014 | 08:15 AM
veloz's Avatar
veloz
i had the same pblm, mine looked really bad discolored..., i ended up wrapping it with vinyl...that piece is semi hard rubber, i would just prep it and paint it..pretty easy to do..the piece comes off really easy...
before
after
Old May 21, 2014 | 09:01 AM
dvilin's Avatar
dvilin
Old May 21, 2014 | 10:46 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I use Adams and I don't have this issue. As mentioned try cleaning them and then reapply the VRT. Use Isopropyl Alcohol to clean the trim pices and then the VRT should be fine.
Old May 21, 2014 | 10:51 AM
zero11's Avatar
zero11
303 my friend one of the best products out there.
Old May 21, 2014 | 11:00 AM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
Originally Posted by BWF07
I use Adams and I don't have this issue. .
I second that and swear by Adams VRT dressing. Could it be that you have a hard water issue?
Old May 21, 2014 | 11:01 AM
psp6158's Avatar
psp6158
Another vote for 303...
Old May 21, 2014 | 01:24 PM
rado63's Avatar
rado63
I have used Mr Clean Magic Eraser on those parts to remove the white residue, followed by Aero 303. Don't use the magic eraser on painted surfaces, it will scratch.
Old May 21, 2014 | 01:37 PM
SCcues's Avatar
SCcues
Pro<br><img src="/forums/images/ranks/500-1000.gif" border="0">
I like Mother's Back to Black also.
Old May 21, 2014 | 01:48 PM
biggerjer's Avatar
biggerjer
Old May 21, 2014 | 01:52 PM
corvetteflier's Avatar
corvetteflier
Originally Posted by dvilin
Me too. Does a good job, just apply liberally and don't get it on the paint.
To Detailing help requested
Old May 21, 2014 | 01:56 PM
duanepillar's Avatar
duanepillar
Old May 21, 2014 | 01:57 PM
woodranch's Avatar
woodranch
Adams VRT is very average and does not last very long.Tried it as tire dressing and was not impressed at all. 303 is your answer.
Old May 21, 2014 | 04:37 PM
hisvett's Avatar
hisvett
Adams VRT is paint friendly, 303 is not......
