Question on Ranger Method
Works for my car.
-G
Pull the cap, pull the rubber piece, clean it off, drain the reserve tank, wipe it out to remove debris in the tank, fill the tank to the top fill line, then as you are putting the folded rubber piece back on with cap, the air on top of the reserve tank will be forced up and out around the rubber piece as the cap is being tightened.
Hence the less air that you have between the bottom of the rubber folded piece and the top of the fluid, the less moisture that will end absorbed in the fluid over time.
If you over fill past the top line, than as you are putting the cap with rubber piece back on, the fluid in the tank will over flow out of the tank as the rubber piece is pushed down with the cap.
As for the bottom line, it a visual line to tell that that the tank is too low with the top still on (read the top rubber piece should have unfolded to stay with the top of fluid line, even with the fluid low in the tank). The concept here, the less you pull the cap, the less new air is introduced to the fluid that moisture can be pulled from it to be absorbed into the fluid.
I fill my reservoir so that when the cap is screwed down it shows full. When the cap is off it shows less then full but the cap fills in the air gap and raises the fluid level when screwed on.
If you do fill it up to the full line and return the cap it will most likely burp out some nasty fluid that eats paint under the clutch fluid cylinder where it will run.
-G
I filled it up and started the Ranger fluid change and run the car a week and then change it and run the car a week and change the fluid again. Still trying to get the fluid clean enough to leave it awhile. Clutch has always worked well, even when the resevoir was empty.
Now the bad side, the system is a close system, so now you have to figure out where the fluid went in the first place. Short of a line leak, you have a connecter between the master and the slave cylinders that may be leaking, or the seals/plungers/cylinder walls scorned, and where the fluid is leaking out of the master or slave cylinder instead.
The Semi bad news, and the reason that you want to keep the fluid clean of clutch dust in the first place, the master cylinder walls are plastic, and since clutch dust is abrasive in the fluid, its the first thing that normally wears out due to clutch dust contaminated fluid.
And I say semi bad, since you can change out the master cylinder through the back wall of the front wheel well, as well as check the connector too (connector comes with the master cylinder).
Its when the slave cylinder goes south that its all evil, since you have to remove the drive line to get to it instead.
