Replacing Brake Light Switch on C6
Old Jun 2, 2014 | 12:54 AM
lakeguy434's Avatar
lakeguy434
Default Replacing Brake Light Switch on C6
have any of you ever had the pleasure of replacing the Brake Light Switch over the Brake Pedal ?? If you have, how in the hell did you do it ??
Old Jun 3, 2014 | 12:35 PM
jedblanks's Avatar
jedblanks
http://forums.corvetteforum.com/c6-c...tantly-on.html
http://forums.corvetteforum.com/c6-c...s-on-help.html
Some suggestions in the threads above, but it sounds like you may need to remove the seat and lay on the floor to reach the sensor. and if replacing the sensor doesn't fix it, then the BCM is bad
