Splitter install
Old Jun 4, 2014 | 07:52 PM
gunnerjuju's Avatar
gunnerjuju
Default Splitter install
I just bought a front splitter from a member but don't have the instructions. I believe they are originally from C7 fCarbon I emailed them but got no reply. I guess they don't care enough to take te trouble to email a PDF. I'll won't be buying anything from them anytime soon no matter how much I like them once installed. Anyway I digress, would anyone have install instruction a the could email me? Thank you
Old Jun 4, 2014 | 07:54 PM
saplumr's Avatar
saplumr
That splitter simply unbolts from a continuous row of screws on the bottom. No biggie!
Old Jun 4, 2014 | 07:58 PM
gunnerjuju's Avatar
gunnerjuju
Don't have to take off the front facia?
Old Jun 4, 2014 | 08:04 PM
EVRose's Avatar
EVRose
Is it a ZR1 splitter? HERE are the instructions I used for my 05. Front fascia does not need to come off. Mine came from RPI but should be the same.
Old Jun 4, 2014 | 08:11 PM
familyman's C7's Avatar
familyman's C7
St. Jude Donor '14
C7 front splitter uses bolt with 2 washers and nut at each attachment point. Use holes in splitter as template to drill underside of facia. Remove all the factory screws under the facia to allow access to tighten bolts from inside of facia. Make sure splitter is evenly lined up with front of front wheels wells and use duct tape to hold it in place to drill the holes.
To Splitter install
