window regulator replacement
Old Jun 7, 2014 | 10:09 AM
jman0110's Avatar
jman0110
Cruising
Default window regulator replacement
I replaced my 2006 driver side window regulator assembly and everything went smoothly; however, the window clamps are stuck at the bottom of the track and they wont go up at all. These clamps were a few inches from the bottom of the track and when everything was put back together, the window would go down to the bottom, then back up to that very low position near the bottom that it started at and back and forth. I cant figure out how to manually move them to the the top of the track or how to get the motor to move it all the way up the track. This is a brand new window regulator. Is there a stopper or something that I need to do to the window regulator assembly?
