Close Call!
Old Jul 1, 2014 | 10:41 PM
FiremanC7's Avatar
FiremanC7
Default Close Call!
I've been having trouble with the Tire Pressure Monitoring System. It kept telling me my passenger front tire was flat, but repeated pressure monitoring showed 32psi. This started in April. I was going to have it checked, but life got in the way.
Fast forward to this past Saturday. My wife an d I put 215 miles on the car running the back roads of Louisiana. When we got home I decided to use my Cub tire monitor to check the inflation of all four tires. The passenger front still showed 32psi. When I checked my passenger rear ( which showed 32psi on the DIS) I got a reading of 5.2psi! I checked it again and then used an analog gauge and got the same reading!
So it looks like the TPMS is set up incorrectly and I put almost 400 miles on a deflated run flat tire (at speeds up to 85 mph)! There is a lesson here. Always check all of your tires even if the TPMS shows all are good!
Now I have to find a new tire since I don't trust the tire to last. It doesn't appear to have unusual wear, but I haven't pulled the wheel yet.
Ouch!
Old Jul 1, 2014 | 10:59 PM
dlind4's Avatar
dlind4
Thanks for the info. I would have done the same thing as you. I would have never thought about that. I think its time for me to dig out my tire guage and check them all.
Old Jul 1, 2014 | 11:50 PM
87SAM's Avatar
87SAM
Hopefully your tire is still fine,maybe a litte extra wear. This has been a common occurrence for years. Some people get a little testy when asked if they checked all tires. Sounds like a good trip. On the bright side, you did not have to deal with a flat tire on the trip!
Old Jul 2, 2014 | 06:59 AM
Don-Vette's Avatar
Don-Vette
Nothing like a good O'l tire gage in the glovebox. I keep one in each car at all times!
Old Jul 2, 2014 | 07:30 AM
LooseScrew's Avatar
LooseScrew
A few weeks back, I had a nail removed from rear right tire. The monitor indicated rear left tire was low. The front sensors were reversed as well. It came this way from the factory, as I hadn't touched the tires since purchasing. Dealer reprogrammed both.
Old Jul 2, 2014 | 08:50 AM
myfunz's Avatar
myfunz
You have to relearn the TPMS.
Old Jul 2, 2014 | 12:16 PM
FiremanC7's Avatar
FiremanC7
I have the Cub TPMS tool and will do the relearn procedure this evening. Best $20 I ever spent!
BobD
Old Jul 2, 2014 | 12:37 PM
Cratchet's Avatar
Cratchet
It seems to me that they ALL came wrong from the factory. That's my opinion so far.
That wasn't nice to fool me like that.
Mike
Old Jul 2, 2014 | 01:52 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I wouldn't replace the tire, just keep an eye on it after bringing it up to normal pressure. I don't ever depend on TPMS readings, I check my tires regularly with my analog hand held gage.
Old Jul 2, 2014 | 04:30 PM
unixcorn's Avatar
unixcorn
This morning my daily driver told me I had a low tire. Unlike the Vette, it doesn't specify which tire is low or show the pressures, just that one of them is low. I almost prefer this for a car with the same tires because rotation would be a pain. The guy at the tire place checked them all, found a screw in the tire that was low and fixed it. I wouldn't have know there was a problem without TPMS so I am glad it is mandatory. It's like everything else, we just have to know its limitations.
Old Jul 3, 2014 | 12:35 PM
FiremanC7's Avatar
FiremanC7
Default Tire watch
I filled it to 32psi and within 1.5 hours it was down to 26psi. Most shops I contacted don't want to touch it.
So, new tires on rear today!
Old Jul 3, 2014 | 01:54 PM
fireinv38's Avatar
fireinv38
Default tire
be safe brother. sent you a pm re: Chief Chris Mickel. my regards
Old Jul 3, 2014 | 06:04 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Good safe move
Old Jul 3, 2014 | 09:09 PM
69L79's Avatar
69L79
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
A good tire gauge is your friend. I check my tire pressure once a week. Takes a few minutes.
Old Jul 7, 2014 | 04:20 PM
FiremanC7's Avatar
FiremanC7
Ended up buying Bridgestone Potenza RE050A Pole Positions. Used my Cub tire tool to do the re-learn procedure. Now all TPMS Sensors show up in the right positions in the DIS. The affected tire had some unusual wear to it.
BobD
Old Jul 7, 2014 | 05:23 PM
Scruff Vette's Avatar
Scruff Vette
+1 ^^^ Little ole pencil gauge can save you a whole lot of headache.
Old Jul 7, 2014 | 08:44 PM
flyint's Avatar
flyint
Default Cub Tire Tool
BobD
What is the Cub Tire Tool?
Old Jul 8, 2014 | 09:50 AM
Boxcar's Avatar
Boxcar
Life Starts at 120 mph
NCM Lifetime Member
A Cub Tire Tool is a tool used to service your TPMS Sensors inside your wheels. It can relearn, take preasure readings, and interact with the sensor. Best $20 Bucks ever spent.
You can order one from Tire Rack as a close out for $20 Bucks.
Old Jul 8, 2014 | 09:54 AM
Boxcar's Avatar
Boxcar
NCM Lifetime Member
BobD
Bob, not trying to be a smart arss...but it is DIC not DIS, Driver's Information Center.
I'm glad you found the problem without major incidents. I track my car, and a tire pressure gage is always nearby. Technology is great, but not perfect.
To Close Call!
