Stiff shifter
Old Jul 6, 2014 | 10:00 AM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
Hey no problem for me, I fully understand! I still really doubt it can be the shifter but anything's possible. Is it hard to move with the engine off just going back and forth in the same gears? The trans fluid change will help no matter, at least it did in my 08 Z06 and it was new. I would use the GM recommended fluid in the differential, it has the needed additives. Let us know how it turns out.
Old Jul 6, 2014 | 10:41 AM
JKbride's Avatar
JKbride
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
Originally Posted by Dano523
Might be time to pull the shifter to clean/polish and relube the shifter box, and maybe even the shifter linkage itself since stiff shifter is screaming after marker short shift shifter.
Videos to help you get to shifter and even pulling it/the box so clean and relube the parts if needed.
http://www.mgwltd.com/corvette_short...allation.shtml
When you reinstall the shifter and box, make sure to index is correctly.
From there, change the oil in the trans to a great synthetic oil, and maybe even the anti venom shim mod to the transmission indexer if the problem is more of a notchy problem instead.
http://forums.corvetteforum.com/c6-t...id-change.html
http://forums.corvetteforum.com/c5-g...procedure.html
this
Old Jul 6, 2014 | 01:30 PM
Dano523's Avatar
Dano523
The diff fluid is just a matter of LS dust off the discs that contaminates it.
So either,
DEXRON® LS gear oil, P/N 88862624
Redline GL-5
Royal Purple Max Gear.
Which all of these has the needed LS modifiers in them.
All of these will work fine, and its more of a matter of fluid changes before the LS clutch pad dust builds up to the point of causing the LS to no longer lock and unlock smoothly; which cause the popping noise of the LS locking and unlocking.
Old Jul 6, 2014 | 01:39 PM
Dano523's Avatar
Dano523
Originally Posted by ProfessorDeath
This thread is....
Yep, all the way to the $2k that it will cost to rebuild a Diff, after you find out that the "break in" metal flake debris off the new metal parts in the diff caused problems (why you change the engine oil after the break in period), such as these debris in the bearing that have caused them to prematurely fail, or the LS clutch packs wearing out prematurely out/rear tires prematurely wearing out, since the LS will not unlock correctly due to the too much worn pad dust in the fluid.
